Question about LeapFrog My Pal Violet
Full factory reset violet
Memory not working
How do I recover space from internal memory on restored Hip street Flare 2? NOT looking to restore lost content, only reclaim "lost/missing" memory space...cannot install anything at all, after factor
If you have done several factory restores, then the internal memory chip is probably damaged and not reading its full capacity.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_e0539de310ea5ad7
Nov 24, 2014 | Tablets & eReaders
I have a LeapFrog My Pal Violet (and Scout). The have been personalized with my child's name and favorite "things". My question is: How do I reset or clear this personalized information...
Here you are. It took a while to find the instructions!
In addition, if you would like to delete the data on your device prior to recycling, open the LeapFrog Connect program, sync your device via USB to your computer, click on the product you would like to reset from the "My Products" screen, then under "Settings," select "Reset". If you have not downloaded LeapFrog Connect, please follow these instructions to do so.
eWaste
Aug 26, 2011 | LeapFrog My Pal Violet
My nokia 5230 says phone memory is full however nothing is being stored on my phone memory. How do i clear spae without resetting the phone to factory settings?
check first if the phone memory is indeed full, it should be under settings then phone. also check if the default memory being used is your phone, if you have a memory card change it to memory card. if your phone memory is full you just need to delete files you don't need. you don't have to reset your phone.
Mar 23, 2011 | Nokia Cell Phones
When i turn my nokia 6303 off it resets everything. my phone memory is not working.all contacts saved in phone memory are not available and new contacts are not saving.phone memory shows empty but when i...
You could try a full Factory Reset - by going into settings and selecting Restore to Factory Default.
If this does not fix the issue then you may have to take it back to the shop you purchased it from as you will have a 2 year warranty.
Dec 16, 2010 | Nokia 6303 Cell Phone
When I try to open a game I get a message saying 'Memory Full'. When I enter memory manager to clear space,only the common memory is full. Can I clear this memory? When I try it asks if I want to clear the...
try moving pictures or applications to your Micro SD card to free up your common memory. Also free up your messages this also caused same problems
Sep 09, 2010 | LG GT505 Cell Phone
My nokia 6233 phone memory was lost.it have no files but showing full.plzzz help me
This problem is mostly caused by memory corruption or insufficient memory. Check your call logs, sms, bluetooth receive sms or files, outbox, sent items, received files and delete or move if there are some which you suspect the cause of the occupied memory. Reset you phone to full factory (Reset Factory). Then restart and see the problem whether it is gone or not. If not Try backing up your files (contacts, messages) using PC suite to your PC. Remove your memory card, scan the memory card with updated antivirus, or format if necessary. Still you are getting the same error message? Remove your sim card, memory card and reset you phone using the code*#7370#. Sometimes, even updating firmware is effective. To do this, you need to go to the repairing shop. Good luck..
May 06, 2010 | Nokia 6233 Cellular Phone
My phone is very slow and freezing alot. also two messages pop up one says "memory full" two says "system error"even though I have upgraded the software and formated the phone like 5 times, making sure...
memory full-it is caused because the phone uses some internal memeory for ram like bluethooth connectio,wifi so please reset your phone to factory settings
system error-this is due to the firmware plz upgrade it to the latest version by connection to the pcsuit and plz do have an antivirus in your mobile
Soft Reset
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Hard reset
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
Enter the code: *#7370# and press Yes to confirm initialization.
Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
Sep 30, 2009 | Nokia N97 Cell Phone
N95 NOT SENDING TXT SAYS MEMORIES FULL
Probably a virus.. setting it back to factory settings will not work most of the time, got the same issue but on my older nokia 6600, try a hard reset.. press #7370#.. this will erase everything in your phone... contacts.. old messages..images.. i mean all.. back up first before doing this.. =)
have fun
Aug 20, 2008 | Nokia N95 Cellular Phone
Memoery full
memory full not connecting.erased all contacts wont let me connect and ament saying memory full?
Dec 15, 2007 | Parrot CK3300 GPS Receiver
Parrot ck 3100 - Memory Full
Try reseting it to the Factory default. it should solve the problem.
Dec 05, 2007 | Nokia N95 Cellular Phone
LeapFrog My Pal Violet Logo
205 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
pramey3
Level 1 Expert
Keith Koene
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
