HTC HD2 Smartphone Logo
A
Anonymous Posted on Jan 01, 2014
Touch screen not responding - HTC HD2 Smartphone
Tablet is not responding ,to any comands
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - How can I reboot my tablet, the touchscreen is not working. ....Sometimes when I turn on the screen it doesn't respond to my fingers. Then I ...
Android Tablet Touch Screen Problem Solution - YouTube
? 21:36
https://www.youtube.com/watch?v=h7_aqvkfKL4
Jun 16, 2014 - Uploaded by SOLOMON BOTCHWAY
I CANT Believe it, i Actually fixed my tablet.. all i did disconnect the ... my touch is working how to fix the screen not showing? ....2 WAYS TO FIX IPAD TOUCHSCREEN NOT RESPONDING - WORKING - Duration: 5:17.
Samsung galaxy Tab S 10.5 not responding by touch ...
? 2:54
https://www.youtube.com/watch?v=XkK9zCx46gs
Jul 7, 2014 - Uploaded by Linkhunter
i just the new tablet by samsung i recharge the tablet after that isnot responding by touch and so Sim card do ...
Touch Screen Not Responding ' DaniWeb - DaniWeb IT Discussion ...
www.daniweb.com > ... > Hardware > Mobile and Wearables
Which model of Ricoh are we talking about here? If touch screen is not responding before replacement, re-calibrate touch screen or replace it. I can help you with the calibration code if you require. If the touch screen is not responding after replacement, check whether the replacement lcd display panel was installed reverse as the connectors will not have contact.
2helpful
3answers
Touch screen not responding on nokia c2-03
my nokia mobile c203 touch secreen not work
Jun 17, 2012 • Nokia C203
Touch screen not working properly, i touch down part of screen and it activate upper options. upper part of screen not responding
TOUCH SCREEN
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take care.
LG Xenon touch screen won't respond. Phone was
make sure that you connected all of the wires. take it to a techy just to make sure
ELo touch screens not responding to the touch?
is the screen worn? you might need to replace the touchscreen glass
My screen is lockedI did a hard reset and screen wont respond
ur touch panel is faulty u have to go to service centre , there are 3 things coupled together Lcd screen then touch panel and then front housing for protection of both , u might dropped it , if ur screen is working partially i mean if it responds to taps at some region of screen then it may be a dust inside the housing u have to clean it from inside if u can , otherwise if it completely not responding then it is faulty touch panel , it will cost u around 50 , 60 $
1helpful
2answers
My touch screen is not responding
My touch screen has not been responding but my navigation buttons are working. I'm not able to check my contacts too.. .
Touch screen do not respond
At times, Touch screen does not respond and phone cannot be unlocked by no means, Problem do not get solved even after restarting phone, removing battery & reinserting etc.. This happend typically during nights when the phone is not used and in the morning, touch screen does not respond to do any activities. after installing a software i had a hard reset, after that my tuch screen did not work.please help meeeeeeeeeeee ! !
2answers
How to adjust sensitivity on ELO Touch Screen monitors
you probably have a capacitive screen, it only responds to finger press. You need a resistive screen to be able to respond to finger, nail, or pen press.
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
