Samsung UN39EH5003 39-Inch 1080p 60 Hz LED HDTV [UN39EH5003] Logo
A
Anonymous Posted on Jan 01, 2014
Back of 39" Samsung led tv bolt size for tv mount bracket
Tv mount bolt size back of 39" Samsung led tv
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on May 22, 2009
SOURCE: samsung tv wall mounting
For a true flush mount installation, you will need to recess your connections (i.e. power, HDMI, S-Vid, etc). Most tvs have the connections coming out of the bottom to allow flush mounting.
If your wall is not drywall, or you really don't want to bother with the expense of recessing your outlets and cable connections, just get a swivel arm mount. It will allow the TV to sit a bit further from the wall and still look ok.
Go to www.monoprice.com for great deals on mounts. I have 3 of them in my house and they are excellent quality.
Anonymous
  • 9 Answers
  • Posted on Oct 03, 2009
SOURCE: purchased universal wall mount kit for Samsung LN46B530
I have found that Home Depot and Lowe's (the bigger hardware stores) do not carry something like this. I alway got to my Local ACE Hardware where they have a whole isle with nothing but screws, nuts, bolts and fasteners. I always find what I am looking for there. So if you have a little hardware store in your area then I suggest trying them. It is alittle more expensive than the bigger guys but always worth it cause you can buy one, Two or 100.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Aug 08, 2010
SOURCE: I have a wall mount
The wall mounting kit should come with all kind of screws to attach the mounting barckets to the back of the TV. Most TV uses metric M5 or M6 screws for the mounting holes on the back of TV, you should be able to get them at HD or LOWE for about 35 cents each.
My kits come with a bunch of Metric screws. Do you have the instruction sheet of the mounting kit?
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Anonymous
  • Posted on Feb 24, 2011
SOURCE: I have a Samsung B2330HD TV with universal wall
I'm told you have to force the M4 screws to fit. This is a computer monitor with a TV Tuner not a TV with a computer input. It was not designed for wall mounting.
Anonymous
  • 20 Answers
  • Posted on Aug 13, 2012
SOURCE: Installing a TV mount on a Samsung 39 led Tv
1/4 to 1/2 inch
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
2helpful
Screw size for wall mount 32 inch model TDE3253
Bolt size is M6 bolt pattern and thread pitch. A 15 to 25 mm long bolt is recommended depending on the thickness of the wall bracket.
I got got this from GPX. If you email them you can get the full TV guide.
I want to fix my lg tv to a bracket but I don't know what screw/ bolts i can use and fix the bracket to the back of the tv thanks.
the screws are philips round head type fine thread u will need to go to a tv bracket dealer shop specify the size of the tv and u will be sold the bracket which comes with the standard screws for mounting
1helpful
Want to mount tv lg 42lg50 42 in. on wall...which screws you use for drywall
You don't use screws for drywall to hang a TV, EVER.  That's a 50 pound TV.  You should only use the heavy stud bolts that came with mounting bracket and bolt them directly into the studs.  If by some chance the mounting didn't come with them, go to Home Depot or Lowes with the mounting tell them what you're doing and they'll get you what you need.  You are using a mounting bracket, aren't you? If by some chance you're trying to do this without a mounting bracket, STOP what you're doing and get a mounting bracket appropriate for your size television.  Go to Monoprice, they're the cheapest and their quality is excellent.  Meritline is good as well, they just take a little longer to get.  See the video below.
utube.png You-Tube video "lCNyc-KgCDY" placeholder [unremark-end]-->(do not delete) utube.png
http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10828
http://www.meritline.com/tv-wall-mount---c-13552.aspx
5helpful
2answers
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
1helpful
Bolt size
They are Metric screws, either M5 or M6, you can get them from hardware store for about 25 cents each, so get different length depend on the mounting brackets.
Wall mount usually comes with mounting screws already.
2helpful
I have a Samsung LE26. I bought a wall bracket for tvs with vesa fittings. Although the holes on the backplate are in the correct place, they holes in the back of the TV are a different diameter to any...
There is no such bolt size as 4.5mm, if you look in to an imperial size bolt instead you will find that the imperial size converts back to 4mm or 5mm (M4 or M5 and nothing in the middle).
Samsung can not advise on the correct bolt for your tv model as they do not have the specification for this, this is a factory error - no other Samsung model hase this problem.
You can use PTFE tape, wrap this around the M4 bolt to give it .5mm, PTFE tape is used by plumbers to make screw threads water tight when using compression fittings.You can buy PTFE tape from any DIY store.
I have a samsung LE model, 32", I bought a TV wall bracket from an excellent website called http://www.mountright.com , they supplied with a UMount TV bracket which came with all the correct bolts for my Samsung TV.
1helpful
3answers
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
2answers
What size bolts for mounting bracket??
I don't know the size but, I can bet it will be a metric bolt.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
