Air Conditioning and Heat for Nissan Pulsar Logo
A
Anonymous Posted on Jan 01, 2014
Heat nissan almera - Air Conditioning and Heat for Nissan Pulsar
mahlon754
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 107 Answers
  • Posted on Oct 09, 2014
mahlon754
Expert
Level 2:
New Friend:
Cheetah:
Answers
107
Questions
0
Helped
17417
Points
189
Check vacuum lines for cracks
2005 Nissan Almera. It wont start and the engine light is off.
Question edited for clarity.
Question moved to model category.
Reset the security system and engine immobilizer. Connect a code reader scan tool as see what it shows.
https://www.google.com/search?q=2005+Nissan+Almera+reset+security
2answers
2006 Nissan Almera. 1.6 automatic. Can I please get the cylinder head bolt torque settings for it?
Here you go, the year is close enough.
What are the Nissan almera 2004 1.6 16v cylinder head ...
Answers https://www.answers.com > What_are_the_Nissan_alm...
Feb 22, 2023 - THE NISSAN ALMERA 2005 1.6 16V CYLINDER HEAD TOURQUE SETTINGS. 1.Tighten 29N.M using the correct sequence. 2.Tighten 50°. 3.Tighten 55°.
My almera tino has suddenly started to over heat even thou the water and oil levels are fine would this be a problem with the thermostat ?
doubt it --- for sudden problems check items like fan operation if electric, viscous fan hub if fitted, blocked radiator fins / corroded fins, failed cat converter blocking exhaust.
run the fault codes to check for any sensor failure.
My 2003 nissan almera 1.5 s loses power when it heats up and wont go over 3000rpm
Advice--- is not listening to anything your told
You go to a shop & see first hand the testing in
progress & the results
Have a shop use a scanner to look at data & road test,
to see if there is any problems
Go on that road test,you do the driving & the mechanic
can look at the data
Resetting after installing a radiator on nissan almera
Not sure on the Almera, but some vehicles need the light to be re-set with a scanner, it has stored the radiator fault in it's memory, trip to a garage I'm afraid.
Heater on nissan almera
That noise is the heater and AC air temperature control electric blend door motor trying to move a duct door that is sticking due to heat warping. You will need to remove the entire dash assembly and replace the blend door. This door is located between the AC core and the heater core and "blends" the air from each (hot from heater core and cold from AC core) to give the desired air temperature,.
1helpful
I have a nissan almera 2001 1500 what model
hi i am not 100% sure but i think it is the P11 144 gearbox its used with the almera qg15de engine. i think it is also used in a primera and almera tino of the same years.
13helpful
Nissan Almera Tino Diesel 2.1 - Temperature control not working
Hi there, very common on these vehicles, you need to remove the heater cotrols and check that the cable hasn't come out, usually the clips that hold the cables in place break causing the heaters to not work properly, Nissan do modified clips now to stop it from happening, it may need a cable too if its too far bent, hope this helps.
2helpful
2answers
MY NISSAN ALMERA KEY LOST AND I NEED THE CODE TO GET A NEW ONE
Contact a local nissan dealer and give them the VIN# and they should be able to help you
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
