Select and hold END OF CYCLE SIGNAL for 3 seconds untill the CONTROL LOCKED status
light turns off. The button you need to hold down is under the louder, softer, and off volume
control buttons.
Unplug or shutdown the circuit breaker for 5 minutes. this will reset the control. if the control remains locked after you power this unit back up after the five minute reset has been initiated, this will confirm a major control fault and you will need to replace the control board in this case.
control locked
the washer says "control panel locked"...how do it get it to release?
the control panel on the washing machine is stuck on controls locked how do I fix this so I can do laundry, same issue as mltaylor07, can anyone help?
