Nokia N70 Cellular Phone Logo
M
Michelle Fitch Posted on Jan 14, 2018
Factory reset on t mobile sparq
How do I do a factory reset on a t mobile sparq cell phone, hoping to solve a white screen, that is not permanent yet and the phone still comes on but occasionally will go to white screen and the clock is not the correct time neither, so I am hoping maybe it's a simple fix instead of a slow death. LOL
My mobile nokia n72 hang and per 1 hour period phone screen are white what is problam some soluction
first try to reset Factory Setting if problem not solve than need to flash with latest flash file, till problem not solve than its Hardware Problem, and to solve it visit a Mobile repair shop
Aug 03, 2014 • Cell Phones
Done on factory reset still not working
Hello:
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234,1122 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
I forgot the screen pattern to my sony lt30p How do I do a factory reset?
Hello Dear:
Default 4 Digit user code: 1234 or 0000
I want to factory reset my t mobile concord
Hello:
Reset settings to default on my t-mobile sparq
Dear:
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Dec 16, 2012 • Cell Phones
Reset factory settings
I forgot my security code my IMEA is 355930046444971, what is my Master code?
Don't use more then time to put wrong codes Because it's allow a few try then it will be permanently locked after then you must be flash on your mobile. i give you the better way to get master reset code. I had this same problem in to my mobile i use this website mobile-unlocker.com to reset my mobile i fell this one is too good to use reset codes.
You can also try to enter the DEFAULT NOKIA CODE: 12345
Try reset phone to factory defaults by entering *#7370# then select yes when asked about restoring to factory defaults.
After the phone was restored to factory defaults, you can now enter new codes for your phone.
Hope this helps.
Thank you for choosing www.fixya.com.If you have any other issues under the sun, just post your questions here and we will provide you the answer.
My lg gw 300 sound is not working i cant so i cant hear if im geting a phone call or listen to music
First ...check if the problem is a software problem by resetting your mobile settings to FACTORY
SETTINGS.
You can Reset your mobile to Factory Reset by typing the code below on your mobile screen:
2945#*# and choose the FACTORY RESET .But before you type the code save your important files or
data,because this code makes a HARD RESET (FORMAT) for the mobile.
After FACTORY RESET ,check if the voice of the mobile speaker came back by try to listen to some
music.If the problem still not solved that means its a HARDWARE problem and the speaker device
in your mobile hardware needs repair or needs to be replaced with a new one.
T-mobile dash
Did you do the MASTER RESET?
1. PRESS AND HOLD BOTH SOFT KEYS.
2. WHILE HOLDING DOWN SOFT KEYS, PRESS AND RELEASE THE POWER BUTTON, WAIT 3-5 SEC. (PHONE SHOULD POWER ITSELF ON BY DOING THIS)
3. RELEASE THE TWO KEYS SOFT KEYS.
4. WHEN SCREEN ON DASH LOOKS LIKE IT'S IN DOS FORMAT, PRESS SEND (GREEN ANSWER KEY)
- If this does not work you can try to flash the phone back to factory. Look up TMOBILE DASH factory flash.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
