Oregon Scientific MEEP Kids Tablet Logo
A
Anonymous Posted on Jan 01, 2014
Meep will not connet to wifi
When trying to connect to wifi I get authentication problem message
MeepTablet
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 61 Answers
  • Posted on Feb 09, 2015
MeepTablet
Contributor
Level 1:
New Friend:
Cheetah:
Answers
61
Questions
0
Helped
11077
Points
68
Here is the remedy for that error:
We've heard a few reports of Wifi connectivity issues recently, among them 'Authentication error'. If you receive this message, our recommended remedy is to remove all Wifi connection information from your Meep, turn off your Meep, reboot your router, then turn on your Meep and re-add the Wifi information. Follow these steps exactly in this order to resolve this error message:
1. Remove all Wifi network information from the Meep's settings
2. Reboot your router
3. Re-add the Wifi network information to the Meep's settings
4. Reboot the Meep.
2answers
How do i update my meep
You may have to set it back up with a user name and so on
How do i fix meep tablet when it says UI has stopped working and meephome has stoped working and it doesnt turn on
For any 'Has Stopped' messages, you'll need to run a factory reset from the Settings menu then re-establish Wifi and recover content in the Meep Store. If it won't power on at all, that is then a hardware issue and would need to go through the OSI call center: 800-853-8883.
Authentication problem
trying dumbing down the authentication on your wifi router. Try these:
turn off 40mhz wide channels
try wpa instead of wpa2
try tkip instead of aes
if all else fails, try wep.
7helpful
Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
Tablet will not connect to WIFI
wrong settings issue and also incompatibility issues with software and devices.
Meep problems
If you are receiving a message on your Meep of 'Times Up!', please try the following steps:
1. Register your Meep. Many of the capabilities of the Meep require the parent account to exist which puts the Meep into our system.
2. Adjust your parental settings to allow for times of use. You must set a time limit for every type of allowed activity and then save those settings. If you did set up permissions and you have the Times Up message, check that your settings are the way you set them and haven't been changed. 3. Update your Meep to our latest firmware version using our Meep Ota App available in the Meep Store and through Google Play. Earlier operating versions are linked to the Times Up issue.
If you still have a Times Up message:
1. It could be an issue within your browser in that it's retaining old settings and not updating them. Try clearing the browser cache and/or disabling extensions within your browser. Another option is our Meep Together smartphone app which can also be used to adjust parental settings instead of the portal website.
2. It could be your Meep is not connecting at this time to our servers thus not being able to receive the updated settings. Check that you show a green dot which means you are connecting to us or send a Private Message with your serial # and we can check the connection from our side.
3. Another option that bypasses servers is that you can update the settings right from the Meep's own parental control interface, assuming you are on version 2.1. Additionally, within the parental app on the Meep, you can reset the timer for the Meep with the reset button, the small circular icon in the upper right hand corner of the time management screen. Once reset, you can adjust the settings as you wish.
How do I connect to to the internet?
First, connect the Meep to your home Wifi network. CHeck that you have Allowed internet browser use in the parent portal, and use Meep's own custom web browser.
My meep tablet keeps saying times up when trying to open games
MEEP tablet is saying time's up! what can I do to fix?
8helpful
Authentication problem connecting to wifi
Can't get unit to connect to my home wifi , keeps giving message Authentication Problem
Top Oregon Scientific Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Oregon Scientific Tablet and eReader Expert? Answer questions, earn points and help others
