Our washing machine will not stop filling up. It started just on the rinse cycle and now it won't stop even in the beginning when it is putting water in for the first time. We replaced the water level switch already (maytag #21001554) and it didn't help. Any other suggestions?
Check hose to water level switch, if it has had an out of balance situation it can loosen or detach hose. replace hose firmly back on switch or replace hose if that doesn't work.
The hose that goes from the tub to the water level switch might have a small pinhole. replace the hose and you shouldn't have a problem
Most likely it is your lid switch
SOURCE: Washing machine wont stop filling up
i had the same problem and found a piece of trash in my valve. The valves are controlled by a solenoid and are very sensitive.
This is happening to me too! Only on the rinse cycle and I can hear water draining out, while it's filling up and the water never reaches the top, therefore, it continues to run. Anyone have any idea of what this could be? I have a newborn and have more laundry than ever!
washer will not stop filling. water comes out of the lid at the top.
i switch it on it starts putting water through then stops and doesnt do anything else
