What is the best memory card to use in a Kodak EasyShare c142
SOURCE: kodak easyshare cw330 new memory card reads full....
Camera doesn't support more than 1GB memory card, so better use less than 1gb SD card
..........Prashant
SOURCE: memory card
I experienced the same problem with my Kodak C330. I took it to Walgreens and the tech stated that the C330 was created before 2 GB memory cards were invented; therefore, the software inside it doesn't recognize a larger GB capacity. In short, the C330 has a 1GB max capacity. Considering you can take 1200 pictures with a 1GB card, a larger size really isn't necessary.
SOURCE: I put a new memory card in our Kodak EasyShare
Your camera is only supporting SD/MMC Cards (up to 1 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.
1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
SOURCE: My Kodak EasyShare C142 keeps
The card may have become corrupted. Use a separate card reader and download any pictures from the card. Then, insert it into the camera, go into the menu and find "format"...follow the on-screen instructions.
SOURCE: Hello! We just opened my
Some cameras can only use SD cards...not SDHC cards. Check your manual.
