I was charging it when water was spilled on it and now it does not power up. No light on computer when power button is pushed.
SOURCE: My dell D810 won't power up.
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
SOURCE: Dell Mini 10 Won't turn on. When I press the
try to power drain pc first. to do that, turn pc off, remove battery and ac adapter. press down power button for 15-20 sec, then but all back in and try to turn pc on. if still no go, you may need to replace battery or ac adapter, f it still wont work, possible motherboard replacement is needed.
Testimonial: "Thank you so much! This was great to give me a place to start - Dell wanted to charge me just to talk to me. Thank you again!"
SOURCE: I need to restore my
Then definitely you dont have the Default partition on the computer.. If you are under Dell warranty call dell @ 18006249896.. They will give you a harddrive with the default partition.. Else try to get a USB CD drive from friends and reinstall the OS...
SOURCE: my inspiron mini 1011 producing
Thaat isknown as a beep code.
Does your system start up normally?
If not let me know how many beeps and I can let you know what it meens.
SOURCE: my Dell v515w printer
Might need to install the driver for the printer first! If you don't have a disk with the driver, go to the manufactures web site, to their 'driver downloads/downloads/support' where you should be able to find the driver after entering your printer model information.
hope this helps!!
