Question about True 23 cu. ft. / 651 liter Commercial Freezer T-23F
True t-23f troubleshooting - True 23 cu. ft. / 651 liter Commercial Freezer T-23F
Compressor not working
REPLACING TRUE AIR FREEZER COMPRESSOR
Feb 10, 2014 | True 23 cu. ft. / 651 liter Commercial...
T-23f true freezer compressor makes rattling noise then starts sometimes i believe it is the over temp compressor relay
replace the current relay and overload and start capacitor.
look for any looe or damaged wiring as well.
Apr 06, 2013 | True T-23F 23 Cu. Ft. 1 Door Freezer
Regarding replacing the temperature control on the True t-23f freezer, I can't find it.
As soon as you open the freezer door the temp control is at the upper right of the freezer.
Mar 20, 2011 | True 23 cu. ft. / 651 liter Commercial...
I have a True T 23f freezer that I know needs a new defrost timer. My problem is finding the right one. The only numbers I can see on the timer are 8141-00B and 345-00. I can also see it's marked 2hp...
That 8141-00B is a Paragon timer model number. If you get the identical one you can just mark the numbers down and be sure to wire in the new one the same way.
Nov 11, 2010 | True 23 cu. ft. / 651 liter Commercial...
T-23f not freezing
Depends on how technical you want to get. Generally, measure the ambient temp of air entering the condenser coil. Add 30 degrees to that temp and convert to psi using a P/T chart. This will get you to a starting point.Remember, charging a "Hot" box takes time. Don't over charge.
Oct 27, 2009 | True Freezers
True Freezer- The 5 amp circuit breaker trips when the light on
I believe that breaker is actually for door frame heaters. Most true freezers have a resettable breaker for the door perimeter heaters only.
Sep 11, 2009 | True 23 cu. ft. / 651 liter Commercial...
NEED CAPILARY TUBE. WHAT SIZE HOW LONG. TRUE
have ready a correct make and model number and call 1st source at 1-800-392=3939. if u can't get it there, who knows. plz rate me.
Jul 27, 2009 | True 23 cu. ft. / 651 liter Commercial...
T-23F FEERZER
fan burnt or relay fauly or fuse blown
Mar 10, 2009 | True 23 cu. ft. / 651 liter Commercial...
True 23 cu. ft. / 651 liter Commercial Freezer T-23F Logo
101 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Joe Palazola
John Carter
John Carter
Level 1 Expert
Are you a True Freezer Expert? Answer questions, earn points and help others
