I have tried the component out, s-video out, and composite out to no avail. When I click on "Display" on the remote nothing happens. Any ideas. My ultimate issue is trying to hook up a subwoofer, but according to the owner's manual, I need to go thru the MANUAL SET UP menu, which is accessed thru OSD.
SOURCE: yamaha RX-V530 no OSD
There is no OSD on this unit. The Monitor Outputs are there in case you run video inputs to the receiver, which you don't.
SOURCE: Yamaha RX-V730 OSD problem
I assume you have a component connected source coming into the Yamaha to give it sync and you are component connected out to the monitor. If you have no input you won't have osd on component only without a signal to sync lock.
It is always possible that the 730 doesn't actually have component overlay for osd, just its a 2in 1 out switched affair. Hence the manual says you also need the composite/ Svid as well...They certainly don't use both at the same time. Newer units have full up + down video conversion but at this age it won't have.
SOURCE: I'm trying to get the
I don't think you've set this up correctly. You need to connect to the TV using COMPONENT and S-VIDEO - or COMPONENT and COMPOSITE. You appear to be using COMPOSITE and S-VIDEO, which isn't one of the combinations specified.
After doing this you also need to set your TV to the correct video input mode for the receiver:
I really need to know the brand and model of your TV to tell you how to do this correctly. However, you should look for a button on your TV remote labelled INPUT or SOURCE and press this repeatedly until COMPONENT (or "COMP") or S-VIDEO is displayed. The correct input depends on which connection you are using. If you get a list of INPUTS on your TV screen the first time you press the input or source button, use the arrow keys to highlight COMPONENT or S-VIDEO then press the ENTER or OK button on the remote to select it.
After you've made the connections, the rest of what you are doing is correct - press AMP then the ON SCREEN / DISPLAY button to view the OSD on your TV screen.
Please make sure you have done all of the above and, if you're still having difficulty, please let me know the brand and model number of your TV. If it would help, I can also draw a diagram of the correct connections between the receiver and TV for you.
Hope this helps. If you need further assistance, please reply to me from within this page by clicking on "Add a Comment" below your question.
Regards,
BElectric.
