Canon PIXMA MP470 All-in-One Printer Logo
Posted on May 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Print Head Problem
How can I fix the canon mp470 print head when I just insert a new cartilage. No matter what I do, the printer error stating I didn't install the print head.
JDTec
Level 3:
  • Canon Master 4,338 Answers
  • Posted on May 20, 2009
JDTec
Canon Master
Level 3:
Answers
4338
Questions
0
Helped
2127949
Points
14653
Perform these steps and reset the EEPROM:
Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
4answers
How do I deal with the Check Cartridge U052 message
Solution 1:
  • Remove and replace the cartridges.
Solution 2:
  • Insert new cartridges
Solution 3:
  • Reseat the print head to correct print issues or clear an error.
Solution 4:
  • The print head is broken and it must be changed by a new one.
Source:
http://fix-your-printer.blogspot.com/2010/11/error-u052-on-canon-printers.html
1helpful
Print head is not installed. Install the print head what does this mean?
The print heads nowadays are on the ink cartridge itself, check to make sure that A) there is ink cartridges and B) they are properly inserted.
Failing that take the power out for 2 mins and try again, I'm sure its a loose cartridge though :)
4helpful
2answers
Canon MP470: "Print Head is not installed. Install Print Head"
Some printer brands have a cute scheme that reads a "new" cartridge as good, but the refilled one has a small fuse link that is burned out by the printer. Try factory new cartridges. Unplug the printer power for a bit to reset the printer.
2helpful
2answers
5 amber flashes
Operator error.
Press printer's RESUME button.
If this doesn't clear the error, cancel printing and turn the printer off and then back on.
When press Resume button, ip3000 not responed(not print)
1helpful
5answers
Printer error on a canon mp 470
How I can fix the U051 problem with my conno : MP470 printer ? It says the print head is not installed. Install the print head. Where is the it , and how I can fix it?
please e-mail to [email protected]
Print Head install
Hello Dear,
The Print Head in your printer is physically damaged and so even though it is present and installed it will not be detected by the Printer, you need to purchase and install a new print head for your printer.
Warm Regards,
Manoj Joseph
+91 9352008418
Error Code
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
old marine
old marine
ZJ Limited
ZJ Limited
