Canon Pixma iP4500 InkJet Printer Logo
Posted on May 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yellow ink is not printing properly
My photos are not coming out with proper color. WHen I ran the diagnostic (a few times) the yellow printed unevenly. What can I do
Ramel Mayormita
Level 2:
Sergeant:
  • Expert 240 Answers
  • Posted on May 20, 2009
Ramel  Mayormita
Expert
Level 2:
Sergeant:
Answers
240
Questions
Helped
65531
Points
754
If your yellow cartridge is not fully low ..or have enough ink to print ..no need to replace ..
just run a maintanance .page on it..go to your printer panel select maintenance..and choose clean printhead..
to clean the nozzles of the printhead..
and also try wipe it on a wet cloth to remove the clogs..that cover the nozzles..
please rate it..if it solves your problem..
thanks for using FIXYA..
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
10974
Points
28
I think your cartige yellow ink had finished or dried up what u can do is refill yellow ink or dip cartige into hot water.... and clean it nicely it works
Color mismatch and blurry/smudgy prints
Remove ink catridges and clean print head, shake inks and reinstall the inks, if problem persist, Uninstall the driver and reinstall. thats should help. Some time if the print head are dirty it prints multi color. You have to make sure the Head is Clean and install th inks properly.
2answers
Colour prints coming out with a lilac hue
check whether the printer is in proper mode or not
2answers
Have put new cartridges in and only prints yellow lines
Remove all cartridges, make sure any tape has been removed from over the nozzle. Ensure that everything has been installed properly, then use your printer (prompts on device, or in printer>control panel) to print some test pages, realign heads, etc.
No color from the ink cartridge
hi this is kamal...
pls purchase a color cartridge new... coz ur color catridge is not working properly...
so pls go through this advice... n let me know...
best regards
kamal singh
3helpful
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Colors are not printing properly
Looks like your printer head is in need of replacement
Problems with color prining
hi!!!!
perform maintenance and
try to clean up nozzles may be the ink
clog
or removed the cartriged and clean with alcohol
use cotton buds then placed it back properly
3answers
Poor color printing quality
do you have the canon print management software installed? it's located in the maintenance tab on that software.
www.canon.com has that by model number
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Photo printing
It is definite one cartridge is not running. You do one thing - 1. Write documents in MS-Word - select all - change the color to Red. Take print out. Check Printing is perfect or not.
2. Write documents in MS-Word - select all - change the color to Cyan. Take print out. Check Printing is perfect or not.
3. Write documents in MS-Word - select all - change the color to Yellow. Take print out. Check Printing is perfect or not.
I am sure when you changed the color to Cyan - it did not print Cyan or blank page you got.
So you must replace the Cyan cartridge or may be ink is not coming out through the passage. And first you have to check whether you have removed the plastic tape from the head of t he cartridge.
old marine
old marine
ZJ Limited
ZJ Limited
