Tengo varios meses sin usar mi aire acondicionado. Ahora que voy a encenderlo, el control remoto no le funciona. Abro la tapa y activo el boton de emergencia y tampoco enciende. Que mas debo hacer
SOURCE: My mini split shows f8 and turns on/off alone
The unit is going off on a hi temp .Can you leave it off for a while and then it will start up if you turn it on?I would be checking the fan motor to see it will run alone when the unit stops.Also check and see how hot it is at that time.
SOURCE: The remote for the DSA-122L
First make sure the batteries do not replacing inside the remotes.
