If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: 46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
IT SHOULD BE UNDER WARRANTY. TAKE IT TO AN AUTHORIZED VIZIO SERVICER.
For the 46" TV, it sounds like the main board is bad.
For the 50" Vizio: is the LED light on?
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
