Our freezer doesn't freeze anything we thawed out the ice on the inside and dusted the coils on bottom of fridge and can't keep anything frozen is there a reset
SOURCE: Kenmore Fridge, freezer compartment is cold
Should be around 10 degrees.
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks
and everything shuts down. The heater should now come on. If it does, replace
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
timer again till everything starts back up to end the defrost cycle.
How to check
everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
SOURCE: Refrigerator water condensation drain line freezing
GO TO THE FREEZER PORTION OF THE FRIG.YOU NEED TO TAKE THE ICEMAKER OUT AND REMOVE THE BACK PANEL WHERE THE EVAPORATER FAN IS .RIGHT UNDER THE COIL YOU WILL SEE A DRAIN ,WHEN YOUR FREEZER GOES ON DEFROST THE WATER GOES DOWN THE DRAIN AND INTO A PAN THAT SITS ON TOP OF THE COMPRESSOR.THE HEAT FROM THE COMPRESSOR EVAPORATES THE WATER.THE DRAIN IN THE FREEZER IS PROBABLY CLOGGED OR FROZEN OVER WITH ICE AND THATS WHY THE WATER IS GOING ELSEWARE.REMOVE ALL THE ICE FROM AROUND THE DRAIN.IF THERES A ROD THAT GOES DOWN THE DRAIN FROM THE DEFROST ELEMENT THATS SUPPOSED TO KEEP THE DRAIN FROM ICING UP ,IN ANY CASE THE DRAIN IS CLOGGED OR ICED UP.UNCLOG THE GRAIN AND YOU WILL BE GOOD TO GO.
