Question about Compaq Deskpro EN PC Desktop
Micronpc Clientpro Three beeps on start. moniter does not come on has good video board
Micronpc Clientpro Three beeps on start moniter does not come on has good video board
  • 180 Answers
Remove the Ram and clean the memmory slot and refix the Ram. If still the problem exist reolace the memmory by a new one.
Posted on May 20, 2009
  • 94 Answers
Check to be sure RAM is seated correboot up.ctly. If it is replace with known good RAM and re-try
SOURCE:
Sir...when i start computer..but moniter not start...some beep sound heared in cpu...
check if the mem is right for the board first then check the video card ok.
Oct 27, 2013 | Computers & Internet
Dell studio 1749 has 4 short beeps when trying to start
One Beep (Possible system board failure - BIOS ROM checksum failure)
Two Beep (No RAM detected)
Three Beep (Possible system board failure - Chipset error)
Four Beep (RAM read/write failure)
Five Beep (Real Time Clock failure)
Six Beep (Video card or chip failure)
Seven Beep (Processor failure)
Eight Beep (Display failure)
Feb 12, 2013 | Dell Studio 17 (1749) Laptop black -...
Can i get laptop battery for the model MPD-formerly MicronPC Millenia N5130?
It's very old. If you REALLY want to restore that laptop you will have to purchase some suitable LI-ion cells and refurbish the battery yourself.
A video on how to do an example of this is here:http://www.youtube.com/watch?v=BtqRvAu71Gw&feature=player_embedded
Good Luck
Sep 17, 2012 | Battery Biz MPC (FORMERLY MICRONPC) N5130...
My acer veriton desk top is not booting up and giving a beep continues beep also moniter is not displyaing omething
This is likely a result of the computer not recognizing the monitor. During the POST test during startup,the computer will check for a video output. It can range from the video card failing to just not having the monitor plugged in. I would check you connections, perhaps try a different monitor, even a television that has either HDMI, DVI, or VGA input. If that does not fix it, it is likely your graphics card or on board graphics from the motherboard. Is there anything new since the last time the computer worked? How old is your PC?
Jul 10, 2012 | Computers & Internet
NO VIDEO COMES TO THE MONITER, THE MONITER WORKS WITH OTHER COMPUTERS, ICHANGED THE VIDEO CARD AND STILL NO RESULTS , ALSO THERE IS A LONG BEEPING NOISES THREE TO FOUR TIMES AS I TURN THE POWER BUTTON ON...
It sounds as if your on-board graphics has stopped working. If you have a graphics card to try installing it. That may solve your problem. If not you will have to contact Dell about a motherboard replacement. the last time I looked at a Dell XPS system you can't install a retail motherboard in it.
Nov 24, 2009 | Dell Dimension XPS 400 PC Desktop
I WISH TO KNOW THE NAME OF THE VIDEO CONTROLLER DRIVER FOR MICRONPC TRANSPORT GX3
All mpc computer drivers are available for that model at http://www.mpcdrivers.com
Aug 04, 2009 | MPC Computers TransPort GX3 Notebook
Pc keeps beeping 3 times and nothing on the moniter
remove the RAM(MEMORY CHIPS) from *********** board and reinsert.if the problem is same replace the chips,get new chips.mostly cleaning the golden lines on the chip with pencil/school rubber solves the problem.
No beep is usually a power problem that can be related to the power supply, motherboard or both. Always check your battery power before thinking there is a bigger problem.
Step3
One beep is a normal POST. That means everything is fine. Two, Three, or Four short beeps are normally about the memory of the machine. If there is a problem with one of your memory chips you should get beeps of different combinations in this area. If you get two or three short beeps, one or both of your memory chips could be in trouble.
Step4
Five beeps point toward motherboard or CPU problems. Make sure your memory and video card are seated properly. Try removing them and putting them back in, only if you are comfortable with computers. Six, seven and eight beeps. Eight beeps indicate problems with your video card. Six or Seven are CPU, or a bad chip on the motherboard. Nine beeps mean the BIOS is bad. Replace the motherboard. Ten beeps means the problem is in the CMOS. All chips need to be replaced.
thanks.
Jul 11, 2009 | Asrock 775i65G Motherboard
Powers on MPC comes on screen. One short beep. Hard drive light and another light flicker, then it hangs.
PUT INA WINDOWS DISK OR THE SYSTEM DISK THAT CAME WITH UR CPU AND RESTSRT,,, FOLOW THE DIRECTIONS
May 11, 2009 | MPC Computers ClientPro All-In-One PC...
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
Compaq Deskpro EN PC Desktop Logo
112 people viewed this question
Top Compaq Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
