Question about La Crosse LaCrosse Technology Wireless Weather Station
Faint display on WS-8025u
Hard to read lcd display
LCD display is too faint
Press and hold mic adjust contrast with vol up down while holding mic
Mar 04, 2014 | Toshiba DKT-2020 Corded Phone
Display is too faint
One of the drawbacks of LCD displays is that they can fade with age. If you have an older fax machine, this may be the cause of the fading
Feb 23, 2013 | Office Equipment & Supplies
My 55" WS Mitsubishi projection
The convergence is out, and the convergence ICs' would have to be canged on convergence board, and you are looking a a repair bill between 300-400, and if it was mine for the year that it is I would not lay any money into it, Just buy a new LCD, take care.
Aug 16, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My Toshiba L645D-S4030 is running fine, but the display is extremely dimly lit. I can faintly see the wallpaper on the screen and can faintly see icons/menus when I roll mouse over them, but its too dark...
Most likely the LCD inverter has gone bad. This is the part that provides power to the back-light of the display. In order to replace it, you'll have to get the part number of the LCD. Be aware, they used different LCD in the same size display. It will require removing the bezel and removing the screws that hold the LCD in place so you can get to the back to read the part number of the LCD. The inverter shouldn't cost that much, but if you have a shop do the repair, you're looking at $125-$175. good luck.
If this information was helpful, Please rate it high. thanks
May 09, 2011 | Toshiba Computers & Internet
Does asus notebook u50 have a backlight display?
All LCD displays have a backlit screen. If they didn't, they would be very faint and nearly impossible to read.
Dec 27, 2009 | Computers & Internet
My 2 year old Syncmaster 740N often has multiple faint images behind text in any program and multiple faint desktop icons making it look "smeared"; some days worse than others; resolution is correct at...
Well in monitor you can do one thing - disconnect the monitor cable*(VGA Cable) from the tower and chk still if u have the same faint screen that means monitor gone bad if not than uninstall the Grapics Driver and shut down computer... if u have internet than restart and go to device manager ( Run - devmgmt.msc) under display adapter right click on grapics name and update driver.
Oct 14, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
LCD MONITOR ACER LAPTOP TRAVEL MATE 630 SERIES
FIRST TRY RESTORING YOUR COMPUTER WITH THE RESTORATION DISC THAT CAME WITH YOUR PC (THIS WAY YOU RELOAD ALL DISPLAY DRIVERS & software like itc was from the manufactuer
Nov 19, 2007 | Acer TravelMate 290 Notebook
LCD Display too faint
Replacing the battery won't change anything.The LCD would have to be replaced, there are not any adjustments to change the LCD intensity.
Jun 08, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
La Crosse LaCrosse Technology Wireless Weather Station Logo
43 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
