SOURCE: Norstar m7310 phone
Go to 'Setup / Feature' -> look for the menu item with option as Tone OR pulse...this is where u have to change :)
SOURCE: How do you page with a Meridian Norstar M7208
There is another page, acting more like a directed intercom page...
If you want to talk to someone and you know where they are (general area) you can do a FEATURE 6 6 and the extension number.
This is a direct page and when you page this way, that person can respond back and you can hear them.
SOURCE: Doesnt ring
My BT Meridian compact does not ring after it powered down in a thunder storm. The lines flash and can be answered as normal just no ringing sound
SOURCE: How do you set up caller ID on a Norstar M7208
There are a few other things you need before it will just work on your phones. You need to get Caller-Id activated by your carrier on each of the 4 lines. You also need to make sure your system has a Trunk card capable of Caller-Id. The card in your systems should be labeled CID.
After this you still need to program the lines for Caller-Id in the configuration section of programming.
SOURCE: Norstar M7208 - Only 1 of 3 phones will ring
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
