Question about Poulan Genuine Weedeater Part # 36006-128
Weed eater GTI 17 won't run on high speed
I have a Weed Eater string trimmer that won't run at high RPM's. When the rev's begin to climb, it just cuts out and stall immediatly. It will start again on the first pull with no choke and it will idle. The second I hit the throttle it stalls. The trimmer worked fine earlier in the season( a couple of weeks ago) Any help would be appriciated.
  • 41 Answers
A couple of things may work...
Make sure you have the correct Oil / Fuel mixture, if it is incorrect the motor may have problems running.
Also take off the bottom where the cord is wound up, make sure there hasn't been any grass get wound up inside it, this will cause it to stall out on high RPM.
Posted on May 19, 2009
SOURCE:
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
How to change the fuel filter on a Weed Eater Feather Lite FX265Xtreme 25cc. The weed eater stars but won't run.
Use a hooked piece of wire to snag the filter through the fuel tank, it should pull off the fuel line.
Oct 12, 2011 | Husqvarna Forest & Garden 125c 17"...
I bought this poulan weed eater on 4-2-10 at walmart in westworth village . the trimmer head does ok at any spped for a 2 or 3 minutes then it just goes real slow with the speed at cutting speed . the two...
new doesnt mean free from defects sounds like the shaft is binding can be from a kink or not lubed correctly-- its new so bring back to walmart and replace or return
Apr 14, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
My Ryobi weed eater loses power at working speed after 5 minutes.
you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
Aug 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
My Troy Built weed eater wont keep string going.
troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Poulan Genuine  Weedeater Part # 36006-128 Logo
1,152 people viewed this question
Top Poulan Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Poulan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
