What is the highest capacity SD card that the zr400 will use?
SOURCE: Problem with Canon ZR400 to work with video import
You can download the software here.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=326&modelid=11151
Good Luck and Please Rate FixYa!
SOURCE: Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
SOURCE: whats the highest capacity memomry card that we can use ?
According to the specifications, this model is compatible with the SDHC protocol for memory cards. I believe SDHC cards come in capacities up to 16 MB now.
SOURCE: Problem with the mini SD Card
Thats weird! This is the right size of SD card for your camcorder. http://www.tristatecamera.com/lookat.php?sku=1GBSD80MINI&stsid=CANHG10 Did you try one of the same size?If yes then Did you try an adapter like this one? http://www.nextag.co.uk/INTEGRAL-Micro-SD-Card-1508586241/uk/prices-html?nxtg=16420a280d0a-59E6FEB3CB48EF1E You should get an adapter of appropriate size and place the micro SD card in the adapter and then insert the adapter into the camcorder.
SOURCE: How do you record on
Here is a link to the onwers manual..Look on page 30, there is clear concise directions.
http://www.usa.canon.com/cusa/support/consumer/camcorders/minidv_camcorders/zr850#BrochuresAndManuals
