Canon PIXMA MP780 All-In-One InkJet Printer Logo
Posted on May 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer flashing "wrong cartridge" and won't clear
It is in copy mode and when I tried to print a document, it flashes "wrong cartridge." It won't let me change paper feeder and hitting OK and turning it off per the instructions doesn't work either. How do I get it to stop flashing "wrong cartridge" and what does that mean? Laura D
Anonymous
Level 2:
  • Expert 68 Answers
  • Posted on May 20, 2009
Anonymous
Expert
Level 2:
Answers
68
Questions
0
Helped
35388
Points
152
Laserjet printer stuck initializing
* Check your warranty. Call for support.
*** Following is for information only.***
* Brand and model for specific solution.
* It's probably stuck in error mode. Looking for ink, cartridge level, ID of ink cartridge, communications issues, etc.
* Open your printer control panel on computer to monitor status.
* Stand alone wireless printers will cycle through it's checks and flash ready or error report (by flashing certain lights) you will need to check paperwork for error report.
* Note that with new models(especially cheap units) They tend to take a Long time to process prints and print out. Many render the document to a printer format then print. Copies have to render for each copy.
* I find it faster to render and print one original. Then use the printer's "scan" and "copy" mode as it will not use the render process. Scanning is faster and only done once per "Batch".
Aloha, ukeboy57
2answers
Help! My machine won't copy or print
check the old cartridge was empty or it was just showing wrong indication.( flashing ).
X4270 won't copy after replacing black cartridge. It did run an alignment page, however.
Try this approach:
  1. On the printer operator panel, on Copy mode, press Options.
  2. Select Maintenance.
  3. Select Clean Cartridges
Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that Copying is properly functioning now.
1helpful
2answers
I changed my black ink cartridge and my canon i 70 stopped printing. my computer gives me an error saying there was an error and my document could not be printed. the indicator light is green and then it...
Hi Good day!! did you try to print other documents? if yes try to restart your print spooler Click Start- Setting- Control panel- administrative tools- services now you should be on services box find the "Print spooler" click Print spooler and then restart it by click stop and then start
reply to me for further assistant if my solution did not work thanks
Thank you for using FixYa
The orange lights are flashing, is there something wrong?
Try:
1 Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
2 PPM print speeds are based on the highest speed printer driver mode. Photo print speeds are based on the default mode driver setting using Canon Photo Paper Plus Glossy paper. Print speeds will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. CPM copy speeds based on fast mode setting using plain paper. Copy speeds may vary based on document complexity, copy mode, page coverage and number of copies.
3 USB 2.0 Hi-Speed requires Windows XP, 2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v.10.2 to 10.2.6 operating systems, the printer will operate at USB 1.1 specifications.
Flashing "wrong cartridge" and won't print.
You may have a cartrage in the wrong spot like you may have the coler and the black cartrage swithced from where they should be.
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
6helpful
4answers
Problem printing with HP Business inkjet 1200 1-800-532-4187 IS SPAM
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
old marine
old marine
ZJ Limited
ZJ Limited
