Remote Starter with Keyless Entry Logo
A
Anonymous Posted on Dec 31, 2013
Crimestopper remote start won't sense tach signal when unit is cold
Unit will start and kill truck 3 times when control module is cold. I can warm module with blow dryer and it will work perfectly. It will not sense the tach signal when unit is cold. It doesn't matter about the engine just if the brain of the remote start unit is cold.
Remote starter wont stay started when cold
This is a common problem for remote start units that are installed utilizing the virtual tach (tachless) mode for RPM sensing. For the most part, it is a convenience for installation but it is not the most reliable. The only way to fix this is to have the tach wire of the remote start system connected.
Will not start cold
This is a common problem for remote start units that are installed utilizing the Smart Start (tachless) mode for RPM sensing. For the most part, it is a convenience for installation but it is not the most reliable. The only way to fix this is to have the tach wire of the remote start system connected.
1helpful
2answers
How to program a crimestopper remote control model #chx433tx
To program this remote-
1) Open hood or ground GREY wire @ pin #7 on 12 pin connector coming from Crimestopper control module usually located under dash.
2) Turn key to on position.
3) Press red programming button coming from module 4 times, after a few seconds the parking lights on vehicle should flash 4 times.
4) Press button #1 pause, #2 pause, #3 pause, #4 pause on the remote you are programming, the lights should flash after ever button push. After all four codes (buttons) are learned, the unit will exit code learning mode. If not, turn off key and close hood. Hope this helps......BUZZ
Hi, I have been recently having a problem with my remote starter. It's been working fine for probably 6 months but now when I go to start my car the engine turns on and then turns off right away. I...
If your system is installed in the tachless configuration, you may experience starting problems in cold weather. For some vehicles, this configuration works fine but in others it can be problematic in the cold. The procedure you described is for tach learning. This procedure only works if the tach wire is connected and the module is programmed for tach sensing. You should have the shop that installed the system check and correct the problem.
If you are mechanically inclined and comfortable with working with the automotive electrical systems, you can attempt to make the connections and programming yourself.
The installation manual can be downloaded from here.
You want to connect the green/orange wire to the vehicle's tach source. You did not mention what year, make and model vehicle you have so I am not able to tell you what wire you need to interface. Once the connection is made, you will need to follow the procedure on page 4 of the manual for bank 3 option 5. You want to set it to tachometer input checking mode. See page 22 for the tach learning procedure, once the system learns the tach signal, your system should function properly.
I live in Michigan. I have a Viper remote start and security system. When the temperature is below 30 degrees I have the following problem. When I try to remote start my vehicle, it starts, runs for 2-3...
The remote start has has a status option for it to know when the car has started and for it to keep it running. Most techs do it the lazy way and just set the option to voltage sense. You have to have a tech hook up the tach wire to the remote start and then program it for tach sense.
2helpful
Oil Pressure Problems on a 1988 Iszuzu Trooper
This engine is only the 4ZE1 2.6L EFI in the USA spec-models. The engine will run for a very long time with proper maintenance. Oil pressure falling only after warm-up indicates that the oil, when cold, is thick enough to make the pressure sending unit sense the oil. When it heats up the sending unit may not detect it as the oil thins out. The sending unit is what makes the gauge give an indicator its signal.
I would check the sending unit first, as your concern does not indicate a clattering engine or other problem. This model engine has a circuit that shorts the ignition to ground and kills the engine if the oil pressure ACTUALLY falls below a set minimum. Indicators of this problem are a loud clattering in the engine, as well an engine that will start and then stall for no reason.
2answers
Have installed the Bulldog remote starter in my 2005 jeep liberty. I have to hit the button several times to get it started. I have already changed the jeep's battery.
There is some sort of a feedback to tell the starter if the unit is running - make sure you have the 'tach feedback' connected. There are settings for it to run the starter for specific length of time, or for it to know that it started by the tach feedback. Check your users' manual.
I have a crimestopper security system and the remote 1 way EZ Start remote (cs-34 II TX) battery keeps dying. How do I repair
if the battery keeps dying on your remote it probably has a bad contact somewhere inside you could order a new one from www.crimestopper.com you would have to have your unit model number for them to help you that is located on the unit under your dash
When the car is warm after a while it is hard to start, takes a few cranks. when it starts it smells like fuel. on cold start it is fine.
Kinda sounds like the ECM or "start mixture" control module is faulty or is getting a bad input from a sensor. For example, it man not be getting a proper temperature sense from the exhaust manifold or the intake manifold water temp sensor. So, every start seems like a cold start....
If your cold start is on a "cold" engine - fine. If your cold start is on a "warm" engine - problem. Mixture is too rich for a warm engine.
Again, could be sensor sending a bad temp signal... or the control module not responding to the signal.
A bit too complicated a problem to exactly troubleshoot via long distance... but you now have a starting point.... -Jim
2answers
1997 gmc truck remote start system not letting truck start with in ,i un plug and it fires right back up,if i plug remote start in it wont start with key but will with remote ,i unplug remote key will...
IF ENGINE CRANKS BUT NOT START -, sounds like a short in the tach wire, plug remote starter in and cut the tach wire to the engine for the remote starter. if the truck starts then you remote starter module is faulty.
IF ENGINE WON'T KRANK -, then there is a starter kill hooked in with it. if you bypass this you should be fine. just follow yellow wire from ignition switch till you find where it is cut. rejoin these two yellow wires and you should be good to go
Top Bulldog Security Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
John
John
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
