On this website (link below) you finde fuse box diagram for Renault Kangoo
Renault Kangoo mk1 1996 2006 fuse box diagram Auto Genius
SOURCE: Renault Kangoo starting
Had a look at the fuse (15Amp) that controls the door-locks and the imobiliser?
/H
SOURCE: replace cv boot on a renault kangoo
Did one today, assuming drive shaft removed take off large clip from inner boot slide back joint socket comes away leaving the knuckle joint on the shaft remove 19mm circlip and tap knuckle off spline this allows outer boot to come back - easy enough. Not much tubber to secure new clip over boot though especially with all the grease.
SOURCE: renault kangoo indicators and hazard lights have
Most common cause is a failed indicator relay. Just swap it with a known good one to confirm whether it's faulty but ensure it's correctly rated for your Kangoo.
After that, the next most common causes are more expensive: the indicator switch and the hazard light switch.
SOURCE: Annoying Renault Kangoo electrical problems.
I have a Nissan Kubistar which I understand is the same vehicle as Renault Kangoo.
The key fob works perfectly well most of the time then everyone once and while, the key no longer unlocks the vehicle and then the indicators don't work. After some time, the key works again as do the indicators etc.
I have replaced the battery in the key fob but it doesn't seem to have made any difference.
Any suggestions??
