Smoke and strong burning plastic smell in microwave oven
Burning plastic, not food? A component has overheated badly then, with a plastic case. The main suspect would be the high voltage capacitor in the magnetron supply. This is cheap and easily replaced ONLY IF you know what you are doing and can diagnose the fault. If you don't then DO NOT take the case off the unit as fatal voltages can be present inside even if the unit is unplugged.
I'd just buy another, as they are generally uneconomical to have repaired by a service tech.
SOURCE: left fyring pan in oven during cleaning cycle
hi dr68,
The service techs at servepro fire/water damage cleanup and restoration might have a few free suggestions, they deal with smoke damage/residual odor issues every day.
Servpro Industries, Inc.
801 Industrial Boulevard
Gallatin, TN 37066
Phone: (615) 451-0200
Fax: (615) 451-0291
anaanymous
SOURCE: sparks in oven
the burning is normally caused by a small particle of food getting stuck on the waveguide cover, this then carbonises and starts to arc. replacing cover should return oven to normal
SOURCE: Sharp R-930 Microwave/convection turntable support burned
We have the service manual for this model and have uploaded it for you here.
You can order
parts from Encompass here or you can call them toll-free at 866-779-5835.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: sharp microwave burning smell
Replace the microwave oven, the problem is the magnetron, "heart of the system" and the most expensive part.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
