Dvd disk will not play in sansui player but will play on portable dvd player and computer, I tried copying the dvd in another format and the new dvd, when tried to play in sansui the error incorrect disk c104 came up, any idea what is causing this disk not to play, or can it be reformated someway to play in the sansui player which is hooked up to large tv.
Wrong. I have the same model and was playing a movie the day before, put in the same movie and got this disc error. Tried 10 other movies that I have previously played on this machine and same error. It is NOT the disc.
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
yes, many other dvds play in this recorder, the dvd that does not play is a dvd-r disk, the disk I made a copy on was also a dvd-r disk, when I reformated this disk, the error changed from c105, to c104. Does this error have to do with write speeds, type of format?
the disk is compatible, and the region setting on the dvd is 1, which is the same as the player
do other dvd's play normally?
