iPhone Apps Logo
A
Anonymous Posted on Dec 12, 2017
My kobo wont turn on
Went to charge kobo and the screen went blank and now it wont charge or turn on. The green light keeps flashing, if I hold it the light goes blue and then turns off. Push the on off button again and the green and blue light flash then the green light starts flashing again but no results. The screen remains blank.
micky dee
Level 3:
  • Master 3,015 Answers
  • Posted on Dec 12, 2017
micky dee
Master
Level 3:
Answers
3015
Questions
0
Helped
1060297
Points
8762
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
5 Related Answers
Anonymous
  • 208 Answers
  • Posted on Feb 05, 2008
SOURCE: lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Anonymous
  • 679 Answers
  • Posted on Apr 09, 2009
SOURCE: Blank Screen & flashing button
It is one of three things, One is that it's not recieving a signal, mine flash when the computer is shut down, several monitors do this now. The second is that the either the video card is in need of service, or if you don't have a video card in your machine, it is either a connection that is intermittent, check the other end of the cable, or the monitor is in need of service, there is a circuit board that gives it a boost on start up. How old is the monitor and what brand? all the info is needed to go any further, thanks, if it is 5 years old more or less it is the monitor gone bad, more than likely
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on May 23, 2009
SOURCE: 5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-ballast-assembly/cName/sony-parts
Anonymous
  • 724 Answers
  • Posted on Jul 27, 2009
SOURCE: blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Nov 14, 2009
SOURCE: LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
When you slide the switch back, you should wait 3 sec and then let it go the green light will come on - if screen stays blank re- syncing you e-reader to your computor.
Apr 25, 2014 • iPhone Apps
Samsung st150f
Take battery out and wait 15 minutes and reinstall and charge without turning on the camera, works for me.
3helpful
My touch screen kobo reader has stopped working
Make sure the Kobo is fully charged and switched off. Hold down the 'HOME' key while turning the Kobo on. When you see the power light release the 'HOME' key. The lights will flash. Follow the onscreen prompts.
My Acer Aspire 5100 just went blank. There is a
Generally, an indication that the battery is critically low. It appears that the AC adapter is not powering the system and not charging the battery.
Sidekick Gekko Wont Turn On
try to charge phone battery in 12 volts dc
1helpful
2answers
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
2helpful
3answers
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
Blank Screen No Audio
Ur main video backlight board is dead,must be replace.Try this website,Shopjimmy.com buy the board for $163,replaced it ur tv will work again.
Top Apps Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an App Expert? Answer questions, earn points and help others
