HP LaserJet 3050 All-In-One Printer Logo
R
Rohit Sharma Posted on Dec 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cartige area jam in hp laserjet m1522nf
Hp laser jet m1522nf display so MSG cartage area jam plz help me.
Baja Data / Jay Arias-Chavez
Level 2:
Sergeant:
Champion:
  • Expert 317 Answers
  • Posted on Dec 30, 2013
Expert
Level 2:
Sergeant:
Champion:
Answers
317
Questions
0
Helped
122585
Points
764
Open the cover and remove the toner cartridge, check to see if there is any paper or bits of paper along the path (check on the back as well).
3 Related Answers
Anonymous
  • 87 Answers
  • Posted on Nov 03, 2008
SOURCE: low memory display on HP Laser Jet 3050
Hello All,
Please perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
Anonymous
  • Posted on Jul 27, 2009
SOURCE: HP laser jet 3055 document feeder jam
document feeder jam
Al Toledo
  • 223 Answers
  • Posted on Jul 15, 2010
SOURCE: How to Reset HP Laserjet M1522nf security password
Hi the easiest way is a nv ram
1. Turn the printer off
2. Hold down the down arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This reset will clear all of your saved settings and contacts, if networked print out a configuration report after resetting the printer to view the ip address (IPV4). If the IP address has changed you will need to update the print driver's port tab and update the port.
Good Luck
Al,
[email protected]
2answers
Continuous paper jam in hp laser jet pro m 404dn
Here's a video that can help you with paper jams:
My hp laserjet m1522nf makes a grinding noise and then says add paper' it also makes the same noise when i shut it down and power it up again ... does this mean the printer is garbage?
it could be a bad toner cartridge
try replacing each toner cartridge one by one to see if grinding gear noise goes away.
Or
it could be jammed paper somewhere inside the printer
My printer is HP laser jet M1522nf series. It rotates inside while switching on but no display comes.
Formatter faulty,
Symptoms: No display, not recognized by system,if network cable connected to the port data transferring LED are wont glow or low brightness,
18helpful
3answers
HP Laserjet M1522nf - displaying an "install black cartridge"
this error can be caused by a paper jam, or a little piece of paper in the toner area, Take the cartridge out and use a flashlight to check in the sides looking for paper. Other reason is that sometimes the sensor that detect the toner is out of place and in that case you can try to power cycle with the toner out before you install it again. Good luck
How to install HP laser jet M1522nf and connect my
How are you connecting this printer to your computer ? usb or network ?
If its network i would recommend you to make sure that the IP Address on the printer matches with the one set on the printer driver on the pc
Tryn reinstalling the software a detecting the printer automaticly
1helpful
3answers
What is the Hostname of hplaser jet M1522nf
Any queries regarding Ip-details, please log in to, http://www.ip-details.com/ which gives you the latest information and a accurate solution for your search.
2helpful
2answers
HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
2answers
Laserjet 4 plus printer
printer keeps running until paper tray empty, msg 41.3
k24674
Grand Canyon Tech
Grand Canyon Tech
