SOURCE: yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
[email protected]
SOURCE: Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
