Radio Communications Logo
A
Anonymous Posted on Dec 30, 2013
Schematic diagram kpg 10 for TK 230
How to make a cable radio program
sadiq muhammad
Level 2:
Champion:
  • Kenwood Expert 228 Answers
  • Posted on May 10, 2019
sadiq muhammad
Kenwood Expert
Level 2:
Champion:
Answers
228
Questions
0
Helped
81105
Points
438
4 Related Answers
Patrick Patterson
  • 41 Answers
  • Posted on Nov 11, 2008
SOURCE: Kenwood radio TK270G
The Radio you have is probably an older version, in this case you will need KPG56D. the other possibility is that the software you have is dos driven if this is the case then you will need to install the software on a slower machine with DOS 6.22. I use a pentium pro with windows 98 to program most of my kenwood radios. you will also have to disable any virus software and disable any TSR files on the machine in order to program the radio. The windows base programs don't have these quirks. take a look at your software and let me know what happens.
Pat N5SLI
Anonymous
  • 13 Answers
  • Posted on Mar 27, 2009
SOURCE: How can I program my Kenwood TK-3101 Radio?
Here is a link to the Kenwood TK3101 Manual which explains how to program this radio.
http://www.hitechwireless.com/pdf/Kenwood/TK3101-manual.pdf
If you need custom programming please contact us.
HiTech Wireless 888.511.5162
Anonymous
  • 9 Answers
  • Posted on Sep 10, 2009
SOURCE: unable to program tk-3207
hi, all i can think of is- A, the computer is way too fast for the program you are trying to run, what you need is a really old slow computer or B,
check the COM port settings on your computer.
click start, right click on my computer, click properties, then click on the hardware tab, then device manager.
then there will be a 'Ports COM &LPT' just make sure the com port number is the same one as you are using on the software. Hope this helps.
Anonymous
  • 146 Answers
  • Posted on Oct 03, 2009
SOURCE: Programing KPG-56D
the software is a dos executable. copy it onto your media of choice and paste it into you your other PC. vista will not run this unless you install virtual pc2007 and load win98 in the vista environment. vpc07 is tricky because you have to set up conduits for the virtual com ports that link your physical port. some serial to usb adapters won't function for these. I have had fair luck with kenwood and vertex using this setup.
Howto put a tk290 into program mode
Kenwood KPG-38D CPS Programming Software, for the TK-290 & TK-390 portable radio. Just you connect your radio with programming cable kpg-36 and read your radio and edit it and reprogram it. Also you can program as follows:
Self programming mode Hold down the [Side 1] key and the [Side 2] key, turn the radio power
ON by this way you can enter in programming mode manually.
Can't program tk 3402u16p with kpg 159dn software
try KPG158D two versions of radio, two versions of software
2answers
Join software group download yahoo
The software program is KPG-35D and you need a cable that is KPG-36. I can't help you with the software because it is copyrighted by Kenwood. You should try looking in the Yahoo Groups section for a programming group or Kenwood group. Many have found the road to enlightenment doing so (if you get what I mean).
Looking for a program and cable for a Kenwood TK 2212-1 handheld
Software TK-2212 is KPG-100 and normal kenwood cable KPG-22 can be used for programming.
I need help programming my tk-690 / tk 790 dual head dual band
Try this: join yahoo group Specific to your radio Make/Model, apart from great info you can download manuals, schematics and other goodies for your radio, all this is free.
Note: Re:- Downloads, only if available!!!
I hope this helps you with your query.
Cheers,
Peter
Tk 3312 programming help
I'm guessing you have the software, or you want to obtain the software, either way the solution to your query is right Here: join yahoo group SPECIFIC to your radio Make/Model, the techs there will give you all the help you need, PLUS, you can download manuals, schematic diagrams and yes SOFTWARE for your radio.
All this for FREE, I know, I'm a member of another radio group.
Good luck and Best regards,
Peter
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
Ngoro
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
