My sons leappad 2, is a few days old, the volume worked well until a couple hours ago, now it only works with headphones. is it an easy fix? what can I do to fix the speaker?
I find that there is a problem with your headphone speaker. Try with some other headphone, even if it is not working, then you need to take it to the service center.
selectbanker, As a test only try this. Remove green plug from rear of pc. Find old am/fm stereo transistor radio or even a portable cd player and connect the green plug to your "new" audio source. Can you hear anything coming out of the monitor's speakers? Also try a set of stereo headphones in the green audio "out" jack to see if sound is coming out of the pc. Narrow down where loss of signal occurs first. 12fixlouie
We got our daughter a Leapster2 for Chrstmas 08. One day the sound just stopped working. Called Leapfrog. They said to insert a cartridge, and turn the unit on. Plug headphones into the headphone jack. Then rotate the headphone plug-in 360 degrees,( It is easier to hold the heaphone plug-in and rotate the leapster2). Unplug the headphones and check to see if the sound works. Leapfrog said try it more than once, and if it does not work contact them,1-800-701-5327. We tried it and Hallelujah it worked!
You need to reinstall the latest drivers for your present sound device then restart your pc then check it. It will work surely! you should install the drivers that came with your sound devices! thats it!
