KitchenAid KEMC377K Convection / Microwave Oven Logo
A
Anonymous Posted on Dec 29, 2013
Kp62G0K3 loose microwave door
1helpful
Whirlpool accuwave microwave oven door loose
If the door is loose the interlocking switches will not engauge properly and the fail safe systen will deni access.
It turns but it doesnt get yhe food hot
Hello estela281 :
Your microwave problem could be happen because of a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
That could happen because of slamming the door and not closing it gently .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
Please rate !
2helpful
It's working normally EXCEPT it will not heat food or pop popcorn, etc.
Hello :
It's could be a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
PLEASE RATE !
Timer changing but microwave is not turning on?
Hello :
It's a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
good luck .
please rate !
Kitchenaid Microwave Oven model Kcms1555rss stuck on same cooking time. There is a line with 3 other lines also on the screen
Hello :
It could be a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
Warning : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
My microwave works fine, but the light wont turn on! No matter what i do, resetting it, unplugging it, etc.
Hello :
good luck .
please rate !
The microwave runs, it does not heat (model JVM1431BA 001. What part do I need to replace?
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
regards .
please rate !
1helpful
Won't heat
Hello :
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
My GE Profile microwave oven will not heat! It turns on but doesn't heat... Any idea?
Hello:
good luck .
please rate !
Door to GE spacemaker is loose. EWill only run if
Have the door of your microwave adjusted and screw is tight, so you won't be holding it.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
