Hi my oven wont turn on and the display say LOC and the door is not locked. It wont cancel when I press clear My model #95794
Today the "Loc" light came on and I can not use
the oven... the oven door does open and the
cook top works ok?
I see two others have the same problem.
I tried to un-plug the electric plug but this did
not re-set it?
This unit is about 7 years old. I can not find
the manual. There is no re-set button anywhere
and I also can not find a model number on back?
Hi Sharon Knight - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
My oven is doing the same thing as well as will not let me turn it on.
it continues to display a variety of times.
oven says door locked, door is opened. oven wont clear
I have a 1997 kenmore range model # 880.634619f1 in LOC mode and do not know how to fix this. ive tried unplugging stove but did not work anyone have any ideas
I have the same problem. There is no solution for this. They are showing a solution but it is just another person with the same issue. I need to figure this out before I pull my hair out and just go buy a new stove.
Gas range. Touchpad displays LOC. Cannot open oven. Touchpad beeps as usual. But can't clear lock.
LOC light came on; over door is locked. no oven controls will work
