Microsoft Access 2003 for PC Logo
Anonymous Posted on May 19, 2009
Microsoft access form problem
In a form i want to be able to make it so that in each field something has to be entered how do i do this
Anonymous
Level 1:
Scholar:
  • Contributor 34 Answers
  • Posted on May 19, 2009
Anonymous
Contributor
Level 1:
Scholar:
Answers
34
Questions
0
Helped
18480
Points
78
In the Design view for your form element (eg textbox), go to the Data Tab. Look at the options for:
Input Mask, Validation Rule and Validation Text. You can use any combination of these to force a user to enter something in the field. If you just want to check that the contents of the element has a non-zero length, then you can write an event (Events tab) to check the length of the values entered. If 0, then throw a message box and re-focus the cursor on the textbox.
2answers
I want to create a function in access to calculate a total. Where can I find a step by step guide?
If you already have a field where you want the total to be if you right click on the field and go to properties and find out the name of the field and also the 2 or more other fields that you want to add or multiply together then you can make the total field equal to the formula ie
if you have 3 fields
Field one = value1
Field two = value2
Field total = total
in design mode you would right click on the total field and go to properties and in the properties there should be a field where you can enter a formula.
in there you would enter something along the lines of
=value1.value + value2.value
Then when you have it normal view ie you open it, it should always add the values together and put the sum of them into the total field.
If you want an example database post back and I will create one.
1helpful
I WANT TO CREATE A DATABASE FOR PDF FILES USING MICROSOFT ACCESS
have to follow few steps.
1. new database - give any name
--> design table
e.g id, name and file (the datatype of the file should be hyperlink other wise it wont work)
--> enter some records (in file field write a, b ,c)
--> when you put record in file field then click on hyperlink option on top.. (like first record id=1, name=fahad, file=A) select the A and click on hyperlink option on top and give the hyperlink of the pdf file
--> design the form
--> run the form
--> click on desired file
--> it will open
--> looks complicated but its easy
it will work definitely
Validation code using single loop for multiple fields in javascript
As example, use it:
JavaScript Form ValidationJavaScript can be used to validate input data in HTML forms before sending off the content to a server.
Form data that typically are checked by a JavaScript could be:
  • has the user left required fields empty?
  • has the user entered a valid e-mail address?
  • has the user entered a valid date?
  • has the user entered text in a numeric field?
Required FieldsThe function below checks if a required field has been left empty. If the required field is blank, an alert box alerts a message and the function returns false. If a value is entered, the function returns true (means that data is OK):
function validate_required(field,alerttxt)
with (field)
if (value==null||value=="")
alert(alerttxt);return false;
else
return true;
}The entire script, with the HTML form could look something like this:
<html>
<head>
<script type="text/javascript">
with (field)
{alert(alerttxt);return false;}
else {return true}
}function validate_form(thisform)
with (thisform)
if (validate_required(email,"Email must be filled out!")==false)
{email.focus();return false;}
</script>
</head><body>
<form action="submitpage.htm"
onsubmit="return validate_form(this)"
method="post">
Email: <input type="text" name="email" size="30">
<input type="submit" value="Submit">
</form>
</body></html>
E-mail ValidationThe function below checks if the content has the general syntax of an email.
This means that the input data must contain at least an @ sign and a dot (.). Also, the @ must not be the first character of the email address, and the last dot must at least be one character after the @ sign:
function validate_email(field,alerttxt)
with (field)
apos=value.indexOf("@");
dotpos=value.lastIndexOf(".");
if (apos<1||dotpos-apos<2)
else {return true;}
<html>
<head>
with (field)
else {return true;}
with (thisform)
if (validate_email(email,"Not a valid e-mail address!")==false)
</script>
</head><body>
onsubmit="return validate_form(this);"
method="post">
</form>
P.S.: If this information was helpful, please rate this solution.
</body></html>
No available fields in form wizard
If you select the correct table from the drop down, the fields should be shown in the box. or keep the table open and try creating form. or create a blank form and on the right side you will get tables and fields, you can just drag and drop required fields
Need the ability to "tab" from field to field on right of kybd
When you press ENTER to finish working in a cell, Microsoft Excel moves the cursor one cell down by default. However, you can select the direction in which you want the cursor to move.
  1. On the Tools menu, click Options.
  2. On the Edit tab, do one of the following:
    • To change the direction in which the cursor moves, select the Move selection after Enter check box, and then select a direction in the Direction box.
    • To keep the cursor in the current cell, clear the Move selection after Enter check box.
Note When a range or set of ranges is selected, pressing ENTER moves the cursor within the range or set or ranges only.
Storage of MS-Access 2007
(please refer for www.office.microsoft.com for further information)
Database specifications Attribute Maximum Access database (.accdb) file size 2 gigabytes, minus the space needed for system objects Note NOTE: Although the maximum size for a single database file is 2GB, you can work around this limitation by using a split database. A front-end database file can point to thousands of back-end database files, each of which could be as large as 2GB. For more information, see the topic, Split a database.
Number of objects in a database 32,768 Number of modules (including forms and reports that have the HasModule property set to True) 1,000 Number of characters in an object name 64 Number of characters in a password 20 Number of characters in a user name or group name 20 Number of concurrent users 255 Table Attribute Maximum Number of characters in a table name 64 Number of characters in a field name 64 Number of fields in a table 255 Number of open tables 2048; the actual number might be smaller because of tables opened internally by Access Table size 2 gigabyte minus the space needed for the system objects Number of characters in a Text field 255 Number of characters in a Memo field 65,535 when entering data through the user interface;
2 gigabytes of character storage when entering data programmatically Size of an OLE Object field 1 gigabyte Number of indexes in a table 32 Number of fields in an index 10 Number of characters in a validation message 255 Number of characters in a validation rule 2,048 Number of characters in a table or field description 255 Number of characters in a record (excluding Memo and OLE Object fields) when the UnicodeCompression property of the fields is set to Yes 4,000 Number of characters in a field property setting 255 Query Attribute Maximum Number of enforced relationships 32 per table, minus the number of indexes that are on the table for fields or combinations of fields that are not involved in relationships* Number of tables in a query 32* Number of joins in a query 16* Number of fields in a recordset 255 Recordset size 1 gigabyte Sort limit 255 characters in one or more fields Number of levels of nested queries 50* Number of characters in a cell in the query design grid 1,024 Number of characters for a parameter in a parameter query 255 Number of AND operators in a WHERE or HAVING clause 99* Number of characters in an SQL statement Approximately 64,000* *Maximum values might be lower if the query includes multivalued lookup fields.
Form and report Attribute Maximum Number of characters in a label 2,048 Number of characters in a text box 65,535 Form or report width 22 in. (55.87 cm) Section height 22 in. (55.87 cm) Height of all sections plus section headers (in Design view) 200 in. (508 cm) Number of levels of nested forms or reports 7 Number of fields or expressions that you can sort or group on in a report 10 Number of headers and footers in a report 1 report header/footer;
1 page header/footer;
10 group headers/footers Number of printed pages in a report 65,536 Number of controls and sections that you can add over the lifetime of the form or report 754 Number of characters in an SQL statement that serves as the Recordsource or Rowsource property of a form, report, or control (both .accdb and .adp) 32,750 Macro Attribute Maximum Number of actions in a macro 999 Number of characters in a condition 255 Number of characters in a comment 255 Number of characters in an action argument 255 default.aspx?assetid=za100776681033 Top of Page
Project specifications The following list of tables is specific to Office Access 2007 projects:
General Attribute Maximum Number of objects in an Access project (.adp) 32,768 Number of modules (including forms and reports that have the HasModule property set to True) 1,000 Number of characters in an object name 64 Number of columns in a table 250 (Microsoft SQL Server 6.5) 1024 (Microsoft SQL Server 7.0, 2000 and 2005)
Microsoft SQL Server database Microsoft SQL Server maximum capacity specifications are described in the SQL Server documentation. Form and report Attribute Maximum Number of characters in a label 2,048 Number of characters in a text box 65,535 Form or report width 22 in. (55.87 cm) Section height 22 in. (55.87 cm) Height of all sections plus section headers (in Design view) 200 in. (508 cm) Number of levels of nested forms or reports 7 Number of fields or expressions that you can sort or group on in a report 10 Number of headers and footers in a report 1 report header/footer;
10 group headers/footers Number of printed pages in a report 65,536 Number of controls and sections you can add over the lifetime of the form or report 754 Number of characters in an SQL statement that serves as the Recordsource or Rowsource property of a form, report, or control (both .accdb and .adp) 32,750 Macro Attribute Maximum Number of actions in a macro 999 Number of characters in a condition 255 Number of characters in a comment 255 Number of characters in an action argument 255
Zulfikar Ali
Microsoft Access
You need to set up security and different profiles for different people. that is the safest way. But an easier way is to have you enter data in one form and them enter their data in another form. In their form edit the properties of the fields that you want left alone. You need to set the properties to locked in the form where they do their data entry but leave them unlocked where you do your data entry. Just creat a second form by saving the first one under a different name. Also you might want to remove the fields from the tab stop list.
Access 2007
Breaking a field's title on a report into two line is done in the form design screen. Data table view does not support you need.
Restict closing the main form when some controls on the subform are empty
Hi there. I didn't notice this was so old until I had already worked on it for some time. Did you get this the way you want it? If not, I suggest either using a BeforeUpdate control to ensure the condition is met that the subform contain data, or validate the particular field(s) with isnull. Thanks for posting back if you still need help, or otherwise rating FixYa!
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
