Jura Capresso C1000 Espresso & Coffee Maker Logo
A
Anonymous Posted on Dec 29, 2013
Wet grounds in waste tray c1000 - Jura Capresso C1000 Espresso & Coffee Maker
Tried to rinse with vinegar/water solution, and it worked 2 times, then went back to rinsing into the watse tray. Another problem kept popping up now too. 'Epmty Tray' displays, eventhought
this is a diagram of the drip tray & drip tray contacts for the Jura S-Series S Series Impressa S7, S7 Avantgarde, S8, S9, S9 Avantgarde, S90, S95, C3000 capresso 153, X70, X90, and XS90 One Touch Models.
"EMPTY TRAY" or "EMPTY GROUNDS" (on other machines) is activated when the 2 metal contacts can complete an low volt electrical circuit through high waste water or wet caked-on coffee grounds. the area is marked in RED. careful examine this area and observe the obstruction and gunk and compare with bare clean black abs plastic. the gunk is dull and rough. use soft tools (toothpick, bamboo skewer) to scratch through the gunk. use warm water and soap and a low bristle height brush to thoroughly remove all buildup from this area. dry the metal contact and contacts area with a high percentage alcohol. visualize the insertion slots deep inside the machine (for the metal contacts marked 414) with a flashlight and verify that the female contact point pads have not been bent and are separate and distinct.
the GREEN arrow indicates a thin black plastic finger-like protrusion. this finger (when the tray is inserted) will press against the "TRAY MISSING" small white relay switch deep inside the machine. use a flashlight to visualize the small switch. verify that the switch is securely mounted and clicks when depressed (up) using a soft tool (bamboo skewer) and note the sound. verify the finger is not damaged or chipped off. listen for the sound very carefully when the tray is fully inserted into the machine. if it is not these preliminary factors, the relay switch should be replaced.
I need to clean my capresso c1000. i can't find the instructions. i put a cleaning tablet into the ground coffee area, and ran the ground coffee button a few times. is that it?
No, first push the self clean button (hold until lights come on). Then pull the grounds unit and empty it, that will turn off one red light. Fill the water tank. Then drop the tablet. Then hit the ground coffee button. Cycle through and dump the grounds each time the grounds light illuminates.
1helpful
Is there a operator manual avilable for the c1000
If it's the old Walker w1000 product, you're in luck. http://shop.clarityproducts.com/products/listing/item3189.asp
If that's not it, check your nameplate and post a comment. C1000 does not come up as a valid Clarity part.
Carl
3helpful
C1000 lock
i want to use mts connection in haier c1000
CHINA MOBIL C1000
i want a china mobil model c1000...and i want to now how much is it!!!plz help me
3answers
Jura capresso E8
Did it work before this?
Sometimes hard water can build up and cause blockages.
Try mixing hot water and white vinegar (50/50 mix) and try running it through the machine. If this works, run it through a few more times than run cold water through a couple times to get rid of the vinegar.
Good Luck.
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
