Akai LCT3201TD 32 in. LCD Television Logo
A
Anonymous Posted on Dec 29, 2013
158926 codes What are the directions to input the codes into the remote
1 Related Answer
budlight2k
  • 20 Answers
  • Posted on May 30, 2010
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
How do I turn off a westinghouse tv with a direct tv remote?
Hello Deborah Ingram,
Direct TV remotes have special instructions to "program"
various Television manufacturer's equipment into each of their units. Simply by inputting the appropriate codes the "TV"
Once PROGRAMMED they will operate the set and the "DIRECT" equipment together...
Typically some fine set "MENU" items will not be available... so it is wise the keep your REGULAR REMOTE around for those SPECIAL APPLICATIONS.
24 hour DIRECT contact information is available:
http://www.directv.com/DTVAPP/content/remote_codes2 Remote Control Code Lookup
1helpful
Need code for remote control
Benny, Check the attached links, direct TV codes.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DIRECTV Remote Control Code Lookup
How to Program DIRECTV Remote Control DIRECTV Support
DIRECTV Remote Setup to Change the TV Input Source
4 Simple Steps to Direct TV Remote Codes
Can`t find the code to use my toshiba tv control to work my direct tv satellite to change the channels
try working it the other way, input the code to work your toshiba television from the direct tv remote.
Codes for remote control for direct tv
Insignia TV Code for DIRECT TV is 10463. To program the DIRECT TV remote do the following
1. Slide to TV
2. Press HOLD the MUTE and SELECT
3. If TV Green Light flash 2 times proceed step 4 otherwise goto step 1
4. Release MUTE and SELECT
5. Input 10463.
--done--
I have a Dishn twork box 301 the clerk sold me an echo stare remote 158926 said it would work with this box, but it is not what can I do?
Hello, my name is Becki Barned, with Dish Network customer service. I read your blog, and if this has not been resolved yet, or if you are still having any other problems, I would be more that happy to help you out! You need to program your remote in this case. Pull out the Smart Card in the front of the receiver, which will bring you to system info. Here, with your remote, hold down the SAT button on the top left of the remote, until all the mode buttons light up at the top of the remote, then release. Then press a number between 2 and 15 on the numeric keypad, then press the pound button (#) then record (above the 3) 3 times. This will resolve the remote issue!!!!!
2answers
Lost remote and can't change the input
They sell basic RCA remotes at places like Walmart for about $5.
8helpful
2answers
Press 'Menu'
3answers
Toshiba CT-90275 3 digit code for Direct Tv R-16
Not really too sure about Direct TV. But give me some time, I have asked some other Experts here for their help. Hopefully one or two of them may have an answer..
Please do not rate this solution yet..
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
