Battery compartment on life fitness 95xi?
The battery is located in the front of the rear drive mechanism. It is mounted just below the alternator control board. The following video shows the battery location along with the battery replacement procedure. Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
SOURCE: If the lcd screen for
Hi, depending on whether you have a weak battery or not, first of all replace the battery and if the display does not come up then you definitely have a bad lcd screen which needs to be replaced or check out the the wiring connections that attaches to the lcd screen to confirm if it is connected.
If the wire is connected to the lcd screen, you change the battery and the lcd screen does not come up, you have no choice that to replace the lcd screen.
