Line appeared suddenly, I have owned the TV for less than 6 months. I have tried powering on and off, unplugging from wall. Any solutions would be appreciated.
I assume that when you get the line you lose the picture, if so, you have vertical collapse, either a dry joint in the vertical section or capacitors or vertical I.C., I would doubt that the scan coil would be O/C as that is rare. if you can't do it yourself I suggest taking it to a repairer, as it should be an easy fix...Hope that helps...Phil
