Moultrie Game Spy M-880 Logo
P
Percy MacNiven Posted on Dec 30, 2013
Flash doesnt work
How and when does the white flash work on my 880
A
Anonymous
Check your settings on camera. Go the mode button it will show time and date hit the down arrow key until you get to Time duration make sure it's not set to all day if its go to default settings hit the enter button then hit the up arrow key then hit enter. Test camera in dark area for about 3-4 pic if still not working. Call Moultrie 8006533334 option 1 and 1 for a live person.
2helpful
How do i wire my diehl 880 ?
1) Here is Diehl 880 instruction manual
2) Diehl 880 is 120V timer
-1/2 HP
-1000 Watt tungsten. Tungsten means incandescent light bulbs.
3) Checklist:
a) Your load does not exceed capacity > Timer is too lightweight to control 1500 toaster oven.
b) You need 120V line coming from breaker box with black Hot wire and white Neutral
c) You need 120V line going to Load that also has black and white wire
d) Test each black wire to ground to see which black wire is HOT
4) Deihl 880 sell sheet pdf says 880 is available SPST (single pole single throw) -or- SPDT (single pole double throw).
-The difference is pole #4 on the timer.
-If you are trying to turn one circuit off just as another circuit turns on, then you need the SPDT
-If you are turning one circuit on-and off, then the following instructions are for you
5) Wire clock
-There are 5 poles > look for markings 1-thru-5
-If no marking, then poles 1&2 are probably spaced apart from other poles
-Connect Hot and Neutral wires to poles 1&2 >> this powers clock motor, they go on either pole
-Pole 4 not used
6) Wire timer
-Poles 3&5 are timer circuits
-Connect Hot line to pole 3
-Connect black wire going to Load to pole 5
-Connect white wire from Load to Neutral
My Ada 880 speakers work fine, but the subwoofer isnt making any noise....it doesnt seem like its getting power but if the speakers work id assume the fuse is good right? i cant seem to find alot of...
Hi there bud, this could also mean that something in the Subwoofer has blown or shorted, the best thing to do is too take it back too the shop where you bought it and ask them too replace it .its not worth opening it up yourself and losing the warranty...
Happy new year . Hope you come right :)
1helpful
Epson Stylus Color 880 printer problem
from Kradinsky "Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
1helpful
775Dual-880 Pro cannot detect SATA HDD 320gb
if you bought this board brand new, take it back and tell them the sata controllers in the bois are not sufficent and get one that is. If you got it second hand then you will need to update or flash the bios to the latest version. see if that works and the drive is recognised. if it is recognised via flash/update you may still run into problems if you try to install XP
good luck and regards
Light Flashing
print a test page and allign the cartridges from printer maintenance....
Harmony 880 doesnt work on devices
I did some more searching and it sounds like the IR emitters die. People see to have sucess with replacing the emitters with new or ones from an old remote. I will find out :)
http://forums.logitech.com/logitech/board/message?board.id=remote_hardware&thread.id=724&view=by_date_ascending&page=2
All lights flashing
it might be due to hardware failure plz send it for repair
Coolpix 880 is dead
Sure you can try going to walmarts photo center and putting your card in their machine and seeing if it will work. Just a suggestion.
5helpful
Epson won't print and all lights flash
10helpful
2answers
Epson stylus 880 printer
Top Moultrie Video Cameras Experts
ADMIN Andrew
ADMIN Andrew
Stan Ford
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
