My trannscend hard drive cannot open and it is giving me the message cyclic redundancy error.Kindly help me fix it
SOURCE: F: is not accessible. Data Error (Cyclic
registry may be corrupt...
get Tuneup Utility from my site and install it...
www.sureshayyar.110mb.com Download Page
run TU clean the registry in disk and try
SOURCE: i am getting the data error (cyclic redundancy
Hi, A cyclic redundancy check, known as a CRC error, often occurs when you're attempting to transfer data to a hard drive. It's most commonly caused by an interruption in the recording process, but also can be a sign that you've got problems with your hard drive or optical drive. Here are some steps fixed the issue: Rule out problems with your computer Start by defragmenting your disk. Click the "Windows or Start" button in the lower-left corner of your computer screen and select "Control Panel." Click the "System and Security" icon. Choose "Administrative Tools," then "Defragment your hard drive." This will clear up clutter on your hard drive that could be causing the error Use the CHKDSK program in Windows to see if there are other problems with your hard drive. Click the Windows or Start button and select My Computer or Computer. Right-click the drive with the CRC error. Choose Properties, then select the "Tools" tab. Click Check Now. Make sure the program will fix disk errors by checking the top square in the dialog box. Click Start. Thanks for using Fixya.
SOURCE: unaccessible drive it gives me 2 mesages: m1 :
The first error signals the fact that the partition data is corrupted. The second one signal an error in communication . Both put together signal the fact that your unit has died. You might have a slim chance that the actual disk inside it might have some life left in it: take it out, connect it directly to a desktop and try to access and extract all the files from it.
SOURCE: The Samsung Freeagent GoFlex external
This is a good read on what this error actually means:
http://www.softwarepatch.com/tips/cyclic-redundancy.html
What I recommend is reformatting the drive under Computer Management, and seeing if that fixes the problem.
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
Fix a Cycle Redundancy Check Error
The "Cyclic Redundancy Check" error is a Windows error message telling you there's a problem reading data you're trying to access.
The root of this problem could either be a damaged storage device or a corrupt file.
Windows has built-in tools to attempt to fix to this problem, and avoid further errors.
Click on the "Start" menu in the bottom left-hand corner and click "Run."
Type in "cmd" and press "Enter" on your keyboard.
This will open a black command prompt box.
Type in "chkdsk /f" and press "Enter."
If you receive a message saying the disk will be checked the next time the system starts, press "Y" and then "Enter."
Restart your computer by closing the command prompt box and selecting "Shut Down" from the Start menu.
Wait for the disk scan to reach 100 per cent.
This may take awhile.
When it completes, your drive errors may be fixed.
Avoid future problems with this type of error by replacing the file that caused the problem.
For example, if you got the error when using a text document, open the document and copy all the text (press "Ctrl" and "A" at the same time and then "Ctrl" and "C" at the same time).
Create a new text document and paste the text in by pressing "Ctrl" and "V" simultaneously. Save the new file, and delete the old document.
Hope this heps
