Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
9500HR incline stuck - Life Fitness 9500HR Next Generation Remanufactured Treadmill
3 Suggested Answers
SOURCE:
gymtech
  • 18 Answers
SOURCE: Hi! i have a life fitness 9500HR treadmill and it
Unplug the treadmill . Remove front cover. On the right hand side if you are facing the front - in the siderail is a white switch that tells the treadmill it is all the way down. Check that it is in place and clean.
If you plug the treadmill in.{Do not touch any thing in the motor compartment} When you press start it should go all the way down [home] to contact the switch. You can also see the lit motor turn at this time before the belt will move it must be all the way down.
Posted on Feb 09, 2010
outfield502
  • 79 Answers
SOURCE: Sir, i have a life fitness
please check the fuse of 0.3 amp is located in the front of the machine revises this swicth home underneath the left side of the machine or check for side always in the left if the cables are not disconnected last step and check the capacitor is located on the hoist motor any question send me a message cardiotech_me@hotmail.com
Posted on Sep 15, 2010
I have a Horizon HTM 3000 treadmill which is stuck on max incline and require the incline calibration code.
hi, i also have problem with my horizon htm 3000, incline motor stuck.
did anyone know where to buy brand new incline motor?
and how much it will cost?
Nov 16, 2013 | Exercise & Fitness
We have Lifefitness 9500HR Treadmill. I am getting a Bad Controller Error. We have two 9500HR models. I swapped out Controller, with working 9500HR and still get Error. Keeps going into Notify Maintenance....
I would suggest swapping the consoles to see if the problem follows. If this does not help you figure it out, you are more than likely looking at a wiring issue.
Sep 23, 2013 | Life Fitness Exercise & Fitness
I have 9500HR Treadmill Lifefitness, Lift keeps increasing when pushing the down button.
RUN the software calibration for easy diagnostic and fix it. Go under the HOOD motor, and follow the steps.
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Sep 23, 2013 | Life Fitness LifeFitness 9500HR Treadmill...
I had a lift motor go out on my 9500hr treadmill, I changed the lift motor. Now when i try to get the treadmill to inclin it only does it in the manual mode. when i try to get it to incline through the...
1) Try to measure the if there are 110Vca in the terminal in forward or reverse.
2) Try to measure the ESR from Capacitor and replace it.
3) If you system as LIMIT Switch , test for continuity with DMM for faulty and replace, or some wires loose or disconnect.
4) If you system are Relais see if the relais for UP and down, and working most of them has LED that will be LIT indicating working or NOT
5) If NOT voltage Vca are NOT, coming from The Controller Board Motor, REPLACE IT,
Control board motor has 3 power supply: 1) Console board 2)Elevation Motor 3) Main Motor.
Some IGTBs are Defective.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
LED Blink Patterns on the Control Board Treadmill
Nov 25, 2017 | Life Fitness 9500HR Next Generation...
Sir, i have a life fitness 9500hr. I hit start screen reads incline inoperable. Everything else works but won't incline. Thanks
Aug 15, 2010 | Life Fitness 9500HR Next Generation...
Unit will not start. it does work in maintenance mode. All fuctions work in the maintenance mold. When using the quick start or other setting to start workout, the unit does not start. " Please Wait " is...
Get back into System test hit enter it will automatically to a check once completed. Then go to Lift motor module Go to manual incline and go to maximum incline then to 0 incline then get out of system test unplug unit for about 30 seconds. Then plug unit in if this does not work the limit or home switch may be the culprit
Jun 29, 2010 | Life Fitness 9500HR Next Generation...
Hi have life fitness 9500hr.when i opne MOTER
Every time I have gotten this message, I have had to replace the motor controller.
Feb 27, 2010 | Life Fitness 9500HR Next Generation...
Hi! i have a life fitness 9500HR treadmill and it says incline error on the screen! and the incline doesn't work?? can i fix it somehow?
Feb 07, 2010 | Life Fitness 9500HR Next Generation...
Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
195 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Craig Butler
Craig Butler
Android Man
Android Man
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
