SONY KV-32FD1E - 32" TV The problem showed up with image disappearing, power-on led blinking 4-times, EAT going down. Trying again, the TV stays ON just a few seconds showing the bottom half screen shrink in an unstable manner, then back in protection. Opened it and removed half-a-ton of dust, I found that smoothly turning the EAT regulation the image returns correct size and stable for minutes, but it has some "noise" in it. Please help me!
SOURCE: Vertical lines
This is a defect in the CCD ( light sensor ) - check with Canon and they'll replace it free of charge even if the camcorder is out of warranty.
SOURCE: Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system. Requires a visit to the service shop.
SOURCE: Sony KV-32FS12 32" TV
Hi
It is a problem of high voltage transformer.Better change it.
or
High voltage supply is what give the high voltage power, consisting of components. You ask for this or do you mean you need the High Voltage Transformer or another Item on the board? Do not understand!!
or
Test the Switching Transformer
SMPS switching transformers, like flyback
transformers, are high Q transformers.
They are responsible for transferring a
large amount of energy in a short period
of time. A single turn short will shut down
the SMPS. Be sure to use the patented
Sencore ringing test to test any suspect
switching transformer.
or
call - 1-800-736-2673(toll free)
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
SOURCE: Sony KV-32FS120 blinks 4 times
good day.
Have you tried first resoldering the terminals in the circuitry?
Also, try to check for the ABL supply near the flyback. Watch out for the small voltage zener diodes.
response is highly appreciated.
chris
Dear Sir/Madam,
Click this link for download the manual and check the setting is correct is to set or not?
www.vasst.com/HDV/hdvimages/HVR-A1Umanual.pdf
Thanks
Good luck
Don't forget to rate the solution
