Lexmark T632 Laser Printer Logo
Posted on Oct 18, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DISPLAYING FAX NUMBER ON OUTGOING FAXES
Can you tell me how to get the fax number displayed on outgoing faxes
We are unsure of the number but are able to fax out but not in coz we dont have the number
Does the machine know what the line number is that it is connected to?
Thanks
Heather
Bostik Australia
  • bostik Oct 18, 2007
    Lexmark T632
Soulvisitor
Level 3:
  • Lexmark Master 1,113 Answers
  • Posted on Oct 18, 2007
Soulvisitor
Lexmark Master
Level 3:
Answers
1113
Questions
0
Helped
929803
Points
3125
The machine will print out whatever fax number is programed into its memory not what line it is connected to.
Plug a standard phone into the socket that the fax uses and ring your mobile..
or if just dial your mobile from the fax (type in numbers press send) should see caller id on mobile
I think maybe your setup is a little more complex cause the T632 normally is just a laser printer but you must have the 3100 MFP Option.
manual link
http://www.lexmark.com/publications/pdfs/lexmark3100/eng/userref.pdf
2helpful
Faxes coming in print fine but outgoing faxes people are saying are coming out blank on their end
If outgoing faxes are turning up blank on the recipients end, you may be putting the paper to be faxed in backwards. Outgoing faxes should be sent face-down. If you are sending properly, either your scanner is failing (test it by copying a document) or the recipient is having fax issues on their end.
3helpful
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
3helpful
Phone # on outgoing faxes
"user tools"
"fax features" ok
"general settings" ok
"program fax info" ok
"own fax number" ok
enter number..press "ok"
Please rate solution. thanks :)
5610 issue
dial 9 then pu in 4 to 6 ",,,,,," then the number.
old fashion fax method, don't knock it, it works
2answers
Outgoing Fax on my HP Officejet 6210 All-In-One
The fax machine needs to hear a dial tone first to send a fax. If you have no fax number, what working phone number are you using?
1helpful
Disable receive mode on FAX-2800
NO the best solution is to turn fax machine off after hours
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
