If I remember correctly then you nee to REMOVE the jumper to have it as a slave drive. Otherwise the second from left (with power plug on the right) is usually the SLAVE position on those drives
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
In first HDD put the jumper in first vertical pair of pins from power socket side, it will become master and second HDD put jumper in second vertical pair of pins from power socket side it will become slave.
Most CD or DVD drives installed in modern computers have a group of short jumper pins on the rear of the drive that determine the master or slave setting for the device. The master or slave setting helps to identify the drive when it shares a connector cable inside the computer with another device, such as a hard drive or even another optical drive. Without the master or slave jumper setting, the computer would not be able to tell one device from another or from which drive to retrieve or write data. Configuring a CD drive as master or slave is a relatively simple task that takes only a couple of minutes. Turn the CD drive so that you view the rear of the unit, then check the position of the jumper covers on the set of pins next to the power adapter plug. If the CD drive will be the only device on the IDE data ribbon cable, set the jumper cover on the two pins farthest away from the power connector. This position is the master drive setting, and, by default, most CD drives ship with this configuration. In most cases, if the CD drive is the only device connected to the cable, you do not need to change the jumper setting. Determine if you need to change the CD drive jumper setting if the device will share a connector cable with a hard drive or another optical drive. If the CD drive will be the primary (master) device on the cable, do not change the jumper setting. If the CD drive will be the secondary (slave) device on the cable, continue to the next step to change the setting. Use a pair of needle-nosed pliers or your fingers to remove the jumper cover from the CD drive if the unit will be the secondary device on the IDE ribbon cable. Set the cover over the pair of pins next the pair from which you removed it, then press it until it completely covers the pins. The jumper is now in the slave setting position.
Look for a grid of gold-coloured pins between the power-connector and the data-connector.
Look CLOSELY at the engraving on the top of the disk-drive, near those pins,
looking for 'MA(ster)' or 'SL(ave)' or 'C(able)S(elect)'.
Or, especially for MAXTOR drives, read the text printed on the label on the top of the disk,
for the "pairs" of pins that need to be set.
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
7. Install (or reinstall) the hard drive in the computer. (See "How to Install a Second Hard Drive.")
The motherboard could be the problem. However, you should first check that the master HDD to check if it is corrupted. You can check by either taking the HDD out of the computer and putting it in another computer as a slave HDD (it must be set as a slave drive because the HDD would not work as a master in another computer because the operating system has been configured to run on that one specific computer), you would need to change the drive from a master to a slave by changing the jumper pin found on the one side of the HDD, there should be a diagram on the top of the HDD which will show you how to change the drive from a master to a slave. Then just check that all of the data is on the drive. If it is then you know that the motherboard or the cpu is faulty.
The other thing you could do is if you have another HDD you can swap it out and test if it is working.
Hope this was helpful. Thank you for using FixYa! Have a nice day and please remember to rate this solution.
You need the system info for the laptop you are using to see if a 2nd hdd needs to be set as slave or set in the cable select mode. Either right above the jumper pins or on the top of the hdd above the pins you should see 3 groups of 2 pins. They will be marked, ma, cs, & sl. They may not be in this order as each hdd manufacturer is different but all will have those 3 markings. If you set as slave cover the 2 jumper pins marked sl. For cable select cover the 2 pins marked cs. Hope this helps & please remember to rate my answer.
On the back of the hdd you will see a row of little pins in groups of 2 vertically. It will be marked either right above the pins or on the top of the hdd above the pins, ma, sl, cs. The setting for slave is sl. Put the plastic jumper cap on those 2 pins & it is set for slave. Hope this helps & please remember to rate my answer. Thanks.
Most Maxtor Drives have jumper setting so that if "Jumper 50" is set; the two pins farthest from the power jack, is Master Drive. No pin jumper set, Slave or Cable Select. I hope this helps.
Hi LP, I’ am very familiar with ASUS motherboards. I am thinking you have posted two questions or more referring to the, ASUS K8V-MX board. When you sign into you're FixYa account you than need to click on you're profile. Within you're profiles are the questions you have posted. Click that question to add or see the expert's answer. If you need another question (about the same item) re-post within that same question. You can even copy the link to an older post & past that link into you're next question. (Than I can read you're last question & my responce). LP you have me all mixed up. I'll answer the question you have posted above. In the future please provide you're old post so I understand better.
There is nothing wrong with IDE 250GB drive or the SATA drive. The problem you are haveing is setting the correct settings.
The ASUS K8V-MX can support two serial ATA SATA drives. The SATA drive's can only run at 1.0 version. 1.5GB transfer speed & not SATA II, the 3.0GB speed.
How to setup the SATA drive? Please disconnect any other drives (IDE) & a second SATA drive that may be connected to the system. Except the CDROM drive. Using you're manual the SATA drive should be connected to SATA1 port. Page 1-24 in you're manual. Put you're windows CD into you're CD-ROM drive & boot the PC. You will see, Press any key to boot from CD... (press any key on your keyboard). Windows will start to install. Durring installation of windows the system will restart. You will again see, Press any key to boot from CD... (DO Nothing)! Just allow windows to conintue on its own. Windows will continue to install it's self. This will happed once again, & again do nothing. Windows will finish installing it's self. After windows has finished, load the ASUS CD into you're CD-ROM drive & install it's driver software. Restart the PC. You must register windows. Do so. Than update windows through windows update service. (This will take some time to complete). (Do not install service pack 3). If you have an IDE drive 250GB in size & you installed windows on it. You must erase the drive or it will conflict with you're new installation on the SATA drive. To do this, look on the IDE drive & you will find a large white sticker. Printed on there is instructions of how to set the drive pin. Set the drive up as a slave drive. (This is only temporary). Power off the PC & unplug the power cord. Connect the 250 IDE drive's power cable & data cable. Plug in the power cord to the PC & turn on the PC. Windows will load. Right click once on the start button & slide up to & left click on Explorer. Find the 250 IDE drive, it should be drive letter D or E. Right click the proper drive letter & format the drive. ( Do Not format, Local_Drive C:\ ). Once the format is complete, power down the PC by clicking on the start button & click turn off the computer. Once off, unplug the power cord. Change the pin on the 250GB IDE drive to Master with a slave. Take the 40GB drive & change it's pin so the 40GB drive is a slave. Connect the 250GB drive to the end of the IDE data cable & connect the 40GB drive to the next connector of the same IDE data cable. Re-check all power cables & data cables for good connections before closing the case. Plug the power cord in & power up the PC. Everything should run just fine. Setting the pin for you're IDE drive's can be very confusing. Click on the link below. This will give you an idea of how to set you're pin for a master drive, master with a slave drive. If you post the name ST****** of you're two drives I can post the correct pin locations from Seagate's web site. http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Have more questions about this post? Good luck! Mike
