I'm working on a frigidaire washing machine and need to know how to remove the old timer knob. There were no instructions with the parts to help me out. The old knob has a problem with when you pull it out to stop the washer the arm that is supposed to be behind the dial, slips out and then that stops the cycle settings. We keep the top loose so we can lift up on it and be able to push the arm back in place to make the washer keep on working.
I've replace the inner ring on the door and the latch then reattached the door. But this other part is giving me heck to remove.
Any help would be appreciated.
Thanks
We found this on another web site:
This was super easy. If you can screw and unscrew a nut from a bolt, its that easy.
The Knob assembaly comes as a whole. So once you remove the old knob (unscrew to the Left).
Then replace the new knob assy (screw to the Right) till its a snug fit. As you will see this knob is designed to be a clockwise rotation only - normal operation - sort of a self tightening screw.
