Sentry Fireproof Safe Logo
A
Anonymous Posted on Feb 16, 2018
Door bolts on a Sentry safe A3860 are stuck
The door bolts on our A3860 fireproof safe are stuck in the retracted position. I had to make several attempts before it would open this last time. Now it won't close. I can wiggle the bolts in slightly, but they will not extend, so I think it might be something in the lever mechanism?
Bolts on a SentrySafe A3860 are stuck retracted in the door.
Sentry's Customer Service Department is available Monday through Friday, from 8am - 6pm, Eastern Standard time. Our internet Frequently Asked Questions can be accessed on line 24 hours a day, 7 days a week at www.sentrysafe.com
1helpful
I have a Sentry safe S5741. I have the electronic combo and the key. The door to the safe was locked with the door open. Now the door will not unlock to shut the door. Is there trip to reset the door? Is...
Try changing the batteries first. No the electronic combo would not be erased unless someone previously changed the combination. There is probably something causing the bolts to not retract. The lock may fail if there is any pressure on the bolts and or the door of the safe. Hopefully this information helps.
2helpful
I have a Sentry safe A3860.. I have the combo and
1. Insert a paper clip or pen point into
the small hole of the battery cover located
directly below the keypad. Push in while
sliding cover to the right (Fig. B).
2. Disconnect and remove battery holder.
• Insert 4 new AA batteries (not included)
to power this lock.
• Reconnect the battery holder and put back into proper
position. Slide battery cover back in place.
NOTE: The yellow LED will light when the batteries need
to be replaced.
You can also get the manual here on link below. page 1 tells you how to replace battery.
http://www.sentrysafe.com/pdfs/OwnersManuals/506218.pdf
1helpful
I have a sentry 1250. the door is stuck shut. The dialer won't move but the handle will. how can i fix this?
As a locksmith it sounds like the safe is unlocked and the handle is broken. try turning it on it's side and dropping it this might retract the bolts.
I have a sentry SO500. I know the combination but
A locksmith would try to replace the batteries. Sometimes you will get the green light but the batteries still will not have enough power to retract the latch.
1helpful
2answers
New sentry csw3813 stuck open
do you have the manual i have the same problem but close and the manual is inside the safe is the original keycode but dont remember it
3helpful
Remove the screw from the backside of the door.
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
