HI,
A piece of paper has wrapped around the roller at the back of the printer and I am unable to get it out. Opended the back , front and side. but no luck.
If you cant get paper out from inside after removing cartridge then there is No easy fix, and the roller at rear is called a fuser, these parts dont come out easy,machine will need all covers removed, plugs disconnected and brackets removed, gears pulled off and fuser removed, maybe replaced if there is a reason why it wrapped around roller
I have a hp printer 1200 all in one. Anytime I want to print it says paper jam and it wont print there is no paper in it. How do I correct this proplem please?
Thankyou
A piece of paper is jamed at the end of printer and I can not move it.
I have the exact same problem. The printer took in a piece of paper just slightly wider than 8x12" and it got jammed around the roller in the back (the fuser). I've tried pulling it out, but that just rips the paper and at least 75% of the page is still in there, invisible from all the other openings of the printer.
How much do you think it will it cost me to get this fixed? Yikes.
