Bosch Axxis WFL 2060 Front Load Washer Logo
Posted on May 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove bosch axxis 2060 washer motor
How do I remove an axxis 2060 washer motor? Detail is good!
Mike
Level 2:
Scholar:
  • Expert 190 Answers
  • Posted on Jun 03, 2009
Mike
Expert
Level 2:
Scholar:
Answers
190
Questions
25
Helped
46135
Points
456
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
2answers
Need instructions to stack Bosch Axxis washer & dryer - 24"
You can find the manuals at this link
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Bosch Axxis WFL 2060 Washer, not spinning. Belt looks ok, front filter removed and cleaned. Previous answers say motor brushes, how are these looked at? Access through the back, would prefer not to take...
IF THERE IS BLACK DUST UNDER THE MOTOR IT IS USUALL DEAD. YOU CAN REMOVE MOTOR FROM THE BACK I HAVE DON IT. YOU NEED A METER TO CHECK THE MOTOR. I CAN HELP.
2helpful
The drum stopped turnig and there seewms to be no life in the motor on our BOSCH Maxx WFL 2060 does any one have any idears. Thanks
you need to test the motor to see if voltage is getting to it.. if yes change brushes or motor complete...01179512835
Replacement front door for a Bosch Axxis WLF 2060
Visit repairclinic.com. Enter your model number in the search box and it should call up the parts you need.You'll be able to see actual photos of the parts on size grids so you can compare with what your's look like.
I did a quick search and it looks like you're looking for part number 1046685 .
Is used Bosch Axxis WFL 2060 with door replaced a safe bet
not a bad price (poss a little bit high) but i would want to see it running on a warm wash first.
1helpful
Bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Part number
Go to> espares.co.uk
or > RepairClinic.com
Power to washer is on, but display not responding
maybe door not closing correctly
try a bit of crc in lock to lube otherwise controller shot and brushes worn out in motor
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
