Fujitsu Plasmavision PDS-4242 42 in. Television Logo
Anonymous Posted on May 18, 2009
Fujitsu Plasma Screen won't power up
Fujitsu Plasma (PDS4222W-S) flat screen won't power up. Standby light turns green for split second, hear sound, then standby light goes red. Any reason not to suspect power supply/module as the faulty component?
  • Anonymous Jun 05, 2009
    Thanks for the second opinion -- very helpful!
Anonymous
Level 3:
  • Master 534 Answers
  • Posted on Jun 05, 2009
Anonymous
Master
Level 3:
Answers
534
Questions
0
Helped
256060
Points
1670
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu '[email protected]'
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
1helpful
Toshiba 50hp66 Plasma repeats power sequence without turning on
A case of which came first the chicken or the egg, Power supply board may be the issue or the sustain board--have you looked for the usual bad caps on the power board?
1helpful
Fujitsu P42HHA30ES Plasma TV screen has stopped displaying
It sounds as though you have a fault on the Power supply, the fan doesn't not normally fail on this model. If you'd like your screen repaired, please call 0208 731 3432
Pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
2answers
Plasma wnt stay on
I have had this problem in some models of plasma sets before. In most cases the power supply and main drive boards had to be replaced. In a small number of cases the failure was the screen itself.
In all cases, the cost of the repair was expensive. For the screen failure, the set was scrapped.
Jerry G.
1helpful
2answers
Fujitsu plasma tv connection problem
the fujitsu pds 4222ws uses bnc connectors. they have all kinds of adaptors to use for any type of wire
2helpful
Returns to standby
Green flashing 3 times = digital DC - DC converter fault
Red flashing 3 times = scan circuit fault
Top Fujitsu Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
